Thread: How long to aerate
    Jul 2010
    Double Oak, TX
    44
    How long to aerate
    I am using an aerator modeled after this example: http://www.troublefreepool.com/threa...orching-hot-PA
    TA is pretty high - 175. How long should I run my aeration before testing TA and pH?
    Thanks
    35K gallons, StaRite S8D110 DE Filter, Pentair IntelliFlo vs3050 pump, IG gunite
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: How long to aerate
    This is from "Pool School".
    The acid/aeration process to lower TA:
    1. Add acid to lower your PH to between 7.0 and 7.2 (this also lowers TA)
    2. Aerate until PH rises to around 7.6 (the only way to raise PH without also raising TA)
    3. Repeat steps 1 and 2 until you reach the desired TA.
    You should post a full set of test results, to get the best advice from the forum. Use Pool Math to see how much acid to add. And keep an eye on CSI Index (using Pool Math).
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Jul 2010
    Double Oak, TX
    44
    Right. Thank you. I have read that. I was looking for clock time from someone who might have gone through this before me.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    In my experience, about three hours aeration is long enough to need to lower pH again. That's with 100% return to the spa, but no booster and no air jets. Your pool is larger than mine, though.
    The question is why? Do you have high CH to where the CSI is dangerously high? Are you having to add acid every day to control pH? Or are you just trying to reach a suggested value?
    Jul 2010
    Double Oak, TX
    44
    I have to add too much acid too frequently to maintain pH. Hoping that bringing TA in line with recommendations will help balance the pool and reduce acid demand.
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by dsm View Post
    Okay, that's a good enough reason.
    The acid it takes to lower the TA will end up being the same. You're just speeding up the process. The CO2 does outgas faster at lower pH, so if you've tested and it's up to 7.5 or whatever, you don't need to wait until 7.6 to dose it again. Keep pushing it down. Just don't go below 7.0 or you might start etching the innards of the heater.
