Results 1 to 12 of 12
Thread: Whatever happened to the guy who drained his whole pool?
    My pool was cured!!!!
    It has been crystal clear every day since. I have about 30 PPM CYA.
    The water stays clear with 2 or 3 PPM FC.
    I use tabs with the chlorinator set low. I "shock" with a large bottle of Chlorox once a week.
    I add Polyquat as per the bottle for algae control although I don't know if I really need to.
    NO problems!!! The pool almost maintains itself.
    I think the water was just too cruddy to work with.
    Hal
    "Whatever happened to the guy who drained his whole pool?"
    27,000 gal plaster in-ground
    Compupool 40k SWG from eBay - works great!
    Polaris 380
    Hayward DE
    1.4 HP Hayward Northstar pump
    Two FAFCO Solar Bear panels now heating the pool!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Whatever happened to the guy who drained his whole pool?
    Hal,
    CONGRATULATIONS!!! 8)
    I'm seriously happy that you found your way to a 'trouble free pool' with the help you received here
    Luv& Luk
    -Ted
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Thanks for the update Hal!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Hal3
    Sounds like you really have a Trouble Free Pool!
    I have had tremendous algae problems. My pool maintenance company just "fired" me. Too hard. (I think they were spending more on shock than I was paying them.)
    Aren't you glad that the pool company 'fired' you!
    Congratulations on taking control of your pool!
    Now, when are you going to show us a pic of that beautiful new water?
    You're done SLAMing when:
    Ta dahhhhh!
    Polaris 380
    Hayward DE
    11,969
    OOOOOH AAAAAAAHHHH
    Butterfly's Avatar
    South Carolina
    10,045
    Looks great!
    Thanks for the pic!
    Sure do miss you guys but my pool has been perfect with almost no effort.
    I just replaced a corroded saddle clamp on my chlorinator even though I hardly use it.
    My pool stays clear with 2ppm chlorine.
    My CYA just tested 40 ppm.
    I also have about 30 ppm borate.
    I also added salt to about 1/4 the level that would be used for a salt chlorinator system.
    I continue to add 8oz polyquat per week although I have never seen anything green since the drain and refill.
    Time to start checking the water temp!
    I may be ready for an ice cold dip in a week or two!
    Thanks again!
    Polaris 380
    Hayward DE
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Hal3!
    Where have you been?!
    So, your pool has been perfect with almost no effort. Sounds like you got BBB down pat!
    Hal, if you don't mind, could you please add your city and state to your profile?
    When you say
    ....it makes us wonder where you are!!!
    When summer hits, with a CYA of 40, plus swimmers and warm water, you are probably going to need to reassess your 2ppm FC. I think it might be time to stop using the chlorinator. It looks like your pool is pretty shady, so you don't need to run a high CYA pool to combat full sun, and 40 is right in the suggested range of 30-50. If you continue to use the pucks (tablets) your CYA will continue to rise until you have to drain the pool again!!
    jm2c
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Quote Originally Posted by Butterfly
    Hi Hal3!
    Hal
    I am new to the BBB but I don’t see a “T” in BBB.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    The core elements of the BBB method aren't really the specific chemicals you use, despite the name. BBB centers around using water testing to know what your water needs, using inexpensive chemicals that don't add things you don't want, and paying consistent attention to your pool so the water is kept in balance with minimal effort. Judicious use of trichlor can fit into the BBB system, as long as you are aware of what trichlor does to the water and all of those effects are appropriate given your current testing numbers.
