Thread: Inline Rainbow Chlorinator check valve
    Aug 2008
    Georgetown, TX
    20
    Hey everyone,
    I did a search trying to see if someone asked this question. Didn't, so here goes:
    I have a Rainbow inline chlorinator for my in ground pool.
    I am pretty sure the BB inside the valve is stuck closed. This will be the third time I have had to replace this part.
    I am thinking that due to my equipment being of a higher elevation than the pool, I may not need this valve to begin with.
    Am I wrong? What benefits does this check valve provide for my chlorinator?
    Thanks for reading.
    Dave
    38,251
    Re: Inline Rainbow Chlorinator check valve
    Well, being in TX likely where your pool stays open year round, and where you may have water restrictions, I HIGHLY recommend you ditch the trichlor tablets and switch to bleach.
    As such, it is my opinion that you should not bother fixing it
    Sorry I do not know anything about them or how to fix them.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Aug 2008
    Georgetown, TX
    20
    I actually use both. I primarily use pucks in winter. Right now, water temps are still very cold.
    Also, FWIW, I tried the Liquidator, but gave up on it as clogged easily with the "white stuff".
