Thread: Sand Filter @ 40+ psi?
    Jun 2012
    N. Georgia
    17
    My sand filter is running at an extremely high pressure compared to what I've read is "normal". I realize every setup is different but is this too much for a filter to handle? I say 40+ psi because the gauge is pegged.
    Oh and when I originally filled the filter with sand it was reading ~25 or so. Now even after a backwash I can't get it down. If I run just the cleaner it will sit around 30 psi (no main drain or skimmer).
    Any ideas or thoughts?
    Equip Pad:
    IG Vinyl 16-18k gal, Intelliclor IC40 SWCG, Ranger 24" Sand Filter, Jacuzzi Magnum Pump 1 1/2 HP, Pentair GW9500 Kreepy Krauly Great White Pool Cleaner.
    30,419
    Re: Sand Filter @ 40+ psi?
    Few, if any, pumps can produce 40 psi so I suspect the problem is in your guage. It's a cheap fix to replace it and see.
    Jun 2012
    N. Georgia
    17
    I actually have another one. Long story but I'm on my 3rd filter. The 2nd failed under warranty and Ranger just sent a whole new package (valve assembly included) instead of just the tank.
    I'll go try it now and verify I don't have a faulty gauge. Thank you.
    Jun 2012
    N. Georgia
    17
    NICE call! I'm sitting at 24 psi now with main, cleaner, and skimmer all pulling.
    Doesn't that still seem a little high though? I feel good that is true because it matches the other gauge when I first installed it. I'm just nervous because the other 2 tanks both split on the manufacturers mold seam. Granted the first lasted ~13 years with the same pump...The 2nd only 3 months though. Perhaps it was just faulty from the factory and I'm thinking it was pressure related?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,599
    You should be good to go. I believe those sand filters are rated to take 60 psi. Gotta luv those cheap gauges!
    Jun 2012
    N. Georgia
    17
    Quote Originally Posted by woodyp View Post
    Its terrible once something has failed. You lose faith in it and always see it as the weak link.
    Thanks for the feedback!
