Well, for some reason, I was not receiving notifications when people were posting to my thread.
We have still be struggling with Wanda. We have hooked her up with the new hose and she still doesn't move around. We also have a vacuum head that goes on the end of a pole. We tried it last night. Hubby was in the pool with the vacuum and I was outside the pool trying everything we could to get it to work. It had really great suction. If you hold it up off of the floor you can see debris being sucked in to it. When he would put it on the floor then it wanted to get stuck on the floor because ther was so much suction. He would keep it moving along and then all of a sudden we would lose prime on the pump.
Our pump does not have a "vacuum" setting, so we turn it off, hook up the hose, then turn it back on and just put it on filter. Is this correct or are we supposed to use another setting?
I am wondering if this is a problem with Wanda or if is our pump. We get the same issue with the vacuum head as we do with Wanda.
Still looking for suggestions. I am getting really tired of hauling in chlorine and maintaining SLAM level because the water isn't clear. Actually, the water looked really clear the other day, but we can see dirt of some sort on the bottom. I think it is algea. When we get in the pool it stirs up really easily and then the water quickly turns mirky and you can no longer see the bottom.
Please, please, please, any help you can offer would be apprecaited. THANKS!!!
