Thread: Polaris BP4 leak
    Aug 2013
    Mansfield, Texas
    72
    Polaris BP4 leak
    Tomorrow I plan to replace the seals in my booster pump. I have found tutorial son line and found the parts I need. The question I have is how are the two PVC pipes attached to the volute? Do I even need to remove these or can I leave the volute in place and take the pump off the back?
    Thanks for the help. Oh, the lines are solid PVC, no quick disconnect or such.
    Sorry it is a PB4 not a PB4, couldn't figure out how to change to title.
    15,000 gallon plaster pool with spa and water fall, 250 Pentair MiniMax Plus Heater
    Nautilus FNS FIberglass D.E. Filter 48 Sq ft, Leslie's DPD Complete Chlorine Kit + TFTestkits Chlorine & CCs Kit.
    Oak trees overhanging most of pool
    38,475
    Re: Polaris BP4 leak
    You should not need to remove the plumbing to change the seals ... assuming you have enough room behind the motor to split the pump apart.
    Aug 2013
    Mansfield, Texas
    72
    Thanks jblizzle.
    Your name reminds me of a joke my son told me.
    Why does Snoop Dog carry and umbrella?
    Fo drizzle.
