Thread: Help with plug for Intex Sand Filter
    May 2012
    Montgomery, AL
    15
    I have an Intex Sand Filter and I need to replace the to electric cord. The GFCI end on the cord leaks and is no longer waterproof so sometimes it gets water in it and will not work unless I open it up and let it dry out. The cord says "Caution - Replace only with cord set number SJTW". I looked on Intex's website and could not find a replacement cord so I need help finding the correct cord for my pump. Anyone got any suggestions?
    18' X 48" Intex Ultra Frame AGP, approx. 6,400 gallons
    2650 Intex Sand Filter
    Intex SWG (w/ copper unplugged)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Help with plug for Intex Sand Filter
    I did a little looking around. That's a pretty generic thing, I think.
    I'd just remove it and take it to a good hardware store and see if they can't match it with something there.
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Here is a couple options. LINK Or you could just put a regular plug on and make sure you have a GFCI outlet that it plugs into. Good luck.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    jmcdtucson's Avatar
    Jun 2014
    317
    There are also GFCI power strips you could buy and plug into that. As a bonus any other near-water accessories can plug into that.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
