Thread: Pad for pump
    Aug 2014
    Placentia, ca.
    12
    Pad for pump
    OK, I pick up my new pump tomorrow but I have a question about bases. When the pool was installed about 13 years ago. They used a pre-cast concrete pad for all the equipment. When the 2.0 hp Hayward Northstar died I replaced it with a 2.0 hp Hayward Super Pump (not the right pump). I now will be replacing the dead Super Pump with a Hayward TriStar 2.0 hp. The Super Pump was smaller and needed me to raise the base now the TriStar will need a raised base as well but a bit smaller. Question, what is the best base material to use. I want to build a little form and pour a bit concrete the size of a shoebox lid but that might be over kill. Any ideas?
    18k gl IG pebble attached spa, Goldline aquarite T15, Hayward Superpump 2.0 hp, 500 sqft cartridge filter, Hayward H series 400,000btu heater. All new in 2002 except the pump.
    38,507
    Re: Pad for pump
    Depending on thickness you need, you can find little plastic wedges to put around the pump. In fact one of my pumps may have some with them (but I don't remember)
    Mar 2011
    441
    Re: Pad for pump
    Concrete is fine. I have rubber sound isolation material that I like to use but can be a pain in the butt to get.
    20X40 30,000 gallon gunite pool
    Mar 2015
    Houston, Texas
    14
    Re: Pad for pump
    I have used the rubber garden tiles (18" x 18") cut in half to raise pumps 5/8". It also dampens vibration. They can be easily found at any big box store
    Jun 2012
    N. Georgia
    17
    Re: Pad for pump
    I used 2 pavers (large maybe 12" x 12" to get mine where it needed to be. IMHO I wouldn't pour a little bit of concrete. Just find something that fits and is the right height.
    In the future you may want to change pumps and need the height.
    IG Vinyl 16-18k gal, Intelliclor IC40 SWCG, Ranger 24" Sand Filter, Jacuzzi Magnum Pump 1 1/2 HP, Pentair GW9500 Kreepy Krauly Great White Pool Cleaner.
    Aug 2014
    Placentia, ca.
    12
    Re: Pad for pump
    Also I have heard different answers but do you bolt down the pump or not? I was told by a pool place that they don't bolt them down but what about torque on start up?
