Thread: How far can I put myy pump from my pool?
    Apr 2009
    Lakin Ks
    33
    I have a 5000gal pool and a 1/3hp pump and sand filter. If I plumb with 2in PVC how far away can I place the pump without having an issue with head pressure becoming an issue?
    5,000 gal above ground pool summer escapes pool
    38,540
    Re: How far can I put myy pump from my pool?
    A few houses down.
    Maybe a slight exaggeration, but straight 2" PVC adds very little head loss.
    50 feet is fine. 100 feet will have a noticeable impact, but isn't a problem. 150 feet is likely to cause minor issues. You can go further than that if you up size the pump, but it isn't usually worth it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    What matters most with plumbing and pump size is vertical lift and 45/90 degree bends in the plumbing. Straight pipe length within a few feet of vertical has very little impact to water flow rates.
    Apr 2009
    Lakin Ks
    33
    Thanks! I didn't think it would make much difference. I just wanted the pump and filter close to the garage so no extension cords.
    Sep 2014
    Fort Lauderdale, FL
    146
    100' of 2" PVC has the equivalent head loss of a 1' vertical rise. And even that is at a 20gpm flow rate. Less flow and it's much smaller. That's it. By comparison, a 2" 90 deg elbow is the equivalent of a .1' vertical rise. Put it this way, 5 elbows is the same as 50' of straight pipe. Straight is good, lol...
    *numbers from my handy dandy Pocket Reference book, which all handy DIY types should have.
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
