Results 1 to 13 of 13
Thread: Green Water after adding Chlorine
    Mar 2015
    Kabul
    6
    Threre is 0.32 mg/l copper in my pool. Water is well water. Pool water turns to green after adding chlorine. How can I solve this problem?
    38,524
    Re: Green Water after adding Chlorine
    You need to use a metal sequestrant.
    See: http://www.troublefreepool.com/conte...d-metal-stains
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,110
    Being located in Kabul your options maybe somewhat limited, however as Jblizzle stated you need to figure out a way to remove the metals in the water. The link posted above gives you a few options, however your options maybe somewhat limited long term.
    Welcome to the Forum!
    Lee
    Mar 2015
    Kabul
    6
    As I mentioned before, there is not high level of copper.
    How can I make sure that green color is for copper not another thing?
    Mar 2015
    Kabul
    6
    Which kind of CHELATORS & SEQUESTRANTS is useful for copper?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by fatemaakbari
    Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. ProTeam's Metal Magic and Jack's Magic The Pink Stuff (regular), The Blue Stuff (fresh plaster), and The Purple Stuff (salt) are some of the top sequestrants. You can also find many other brands with similar active ingredients, some of which are noticeably less expensive.
    Quote Originally Posted by fatemaakbari View Post
    Copper at 0.32 is more than enough to cause staining and to turn the water green.
    If the water turns a clear transparent green right after adding chlorine it is either copper or iron. If the water is more hazy murky there might be something else going on.
    Mar 2015
    Kabul
    6
    Quote Originally Posted by JasonLion View Post
    Thank you so much for your helping.
    could you help how much sequestrant is enough for this 0.32 mg/l copper?
    when should we add sequestrant to water ( I mean we add sequestrant to raw water then chlorine or to green water which has chlorine)?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    The following dosage is a good estimate taken from Jacks Magic sequestrant directions
    32 oz for each 10,000 gallons of water.
    If you use the well for topping off, then you will need to continue maintence on a weekly basis is 6-8 ozs.
    http://www.poolgeek.com/products/jac...FQ4BaQodyYoAMg
    hope this helps,
    Divin Dave,
    Mar 2015
    Kabul
    6
    What about EDTA as Sequestrant?
    I am not sure can I find these sequestrants in Kabul or no!
    Is there another way to control copper ?
    Mar 2015
    Kabul
    6
    Quote Originally Posted by Divin Dave View Post
    hope this helps,
    Thank you so much
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Well I googled EDTA (Edetic Acid). Looks like its used in the medical field to treat a variety of ailments. It also says;
    EDTA is a chemical that binds and holds on to (chelates) minerals and metals such as chromium, iron, lead, mercury, copper, aluminum, nickel, zinc, calcium, cobalt, manganese, and magnesium. When they are bound, they can't have any effects on the body and they are removed from the body.
    No idea if it will work as a sequestering agent.
    Divin Dave,
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum Fatemaakberi
    When you have a chance can you please add you pools information to your signature so we have an idea of how much water and what equipment you have ??
    Signature
    Please put the following information in your signature.
    The size of your pool in gallons
    If your pool is an AG (above ground) or IG (in ground)
    If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    Date of pool build/install, particularly important if less then a year old.
    What kind/model of water test kit you are using
    Other significant accessories or options, such as a spa , SWG, or cleaner
    Solar Blanket, Well Water, Borax Added. 76
