Thread: Fountain JVA Not Working
    Jul 2014
    Raleigh, NC
    59
    Guys, I have a fountain in my pool and it is controlled by the iAqualink but it does not work. You can operate the JVA by the on off switch but I don't know if it is setup in the aqualink. Does anyone know how to setup the JVA so I can turn it on and off on the iaqualink. I have a Pool/Spa combo where the spa spills over into the pool. Thanks
    32,000 gallon inground plaster pool/spa combo spillover. Aqua Rite Pro with Sense and Dispense. Jandy iAquaLink Control. Polaris 280 vac. Sheer Descent, Fiber optic deck jet water feature. Vanishing wall. Whisperflo pumps, Pentair clean and clear cartridge filters.
    Re: Fountain JVA Not Working
    The exact procedure varies a little from model to model. Basically, in the setup menus you assign a name to a currently unused AUX. Then assign the valve (JVA) to the same AUX. After that you should be able to turn the valve by pressing the button assigned to that AUX.
    Jul 2014
    Raleigh, NC
    59
    I have the Aqualink rs8 and I have upgraded it to the iaqualink 2.0. When I look at the "Assign JVA" tab it shows the intake is used and the return is used and it shows solar used and cleaner free. I do not have a solar system on the pool so I think maybe the fountain JVA is plugged into the solar connection.
