Thread: Gas heater
    Feb 2015
    Sydney - Australia
    12
    Gas heater
    My 7,500k gallon pool currently has solar heating which was damaged (leaking) when we bought the house.
    I am considering replacing with a gas heater. A gas heater seems ideal for us. Our pool is small so loses temperature quickly but it would be nice to be able to hit a button and a few hours later have nice warm water.
    We have a gas water heater not too far from the pool equipment which seems to have a 3/4 natural gas line going to it. Would this be sufficient to run a heater if the installer tees into it? I don't want to have to run a new pipe from the meter which is on the other side of the house.
    7,500 IG pool in Sydney, Australia
    - Fully tiled in black mosaics
    - Waterco S600 25" sand filter and Onga StaRite silent flow 1Hp single speed pump
    - Zodiac TriMid SWG
    - Zodiac MX-8 cleaner
    38,371
    Re: Gas heater
    Only a very small heater ... maybe ... not sure they make them that small.
    Pool heaters generally use much more BTUs that your entire house. They use a tremendous amount of gas.
    Likely the water heater is a 40-50k BTU heater ... pool heaters are 250-400k BTUs.
    I have a 3/4" pipe running to my entire house (water heater, furnace, dryer, cook top) and a 1.25" pipe running to my pool heater.
    Re: Gas heater
    Gas pipe sizing is dependent on total length from meter or pressure regulator, number and types of fittings used along that path, and total worst case btu load... I'm guessing 3/4" is going to be too small though...
    38,371
    Re: Gas heater
    That is a good point, I do not know if the pressures used are the same in OZ as they are in AZ
    Likely need to talk to an installer.
