Thread: In case your interested-my testing of 10% chlorine I buy and use
    May 2014
    Inverness Fl
    53
    If this is not correct forum-please move.
    I have always been interested since getting my pool, exactly what the % was on the chlorine I buy at "Pinch a Penny", they say it is 10%. They have the best price here. I read of goods ways to test it here but just never did.
    This year just thought I would, I'm paying for it, and they tell me I'm getting 10% chlorine. So I used the method described by CRG_80cc, in this thread "Testing strength of liquid chlorine" where he made the statement of you might get "better accuracy if you do two 1:100 serial dilutions of your sample (still gives 1:10,000 dilution)."
    I have a TF-100 test kit, so I used it to measure the 100 mls of water, doing 2-40mls, and then 1-20 mls to get right amount. I used 5 ml syringe I got at walgreens for the 1 ml. I'm sure that there is a margin of error here, but I also found that it can be very close (acceptable) if you put the liquid on the line when measuring, in the vials and syringe, like you were in an old chem class
    All said and done, I came out with a probably 9.5, and a definite 10 for the chlorine in the jug. I'm on their program of 2 1/2 gal jugs. This is the cheapest way here. Anyway, just thought that someone might be interested, and made me happy in that if my test was even close, I'm getting what I'm paying for.
    Thanks for the help TF-100 and on all the other test.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: In case your interested-my testing of 10% chlorine I buy and use
    I get mine there also, they are pretty cheap...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I had the same curiosity when I joined TFP last year.
    This is a post I made regarding my measurement technique. I generally use 8.25% bleach from Costco, Walmart, Target, or Sam's club. My testing showed the bleach strength to be as advertised, but I always make sure the date code on the bottle is recent.
    My Testing Method
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Orlando, FL
    690
    I get it for PaP or Leslie's too. Cheapest around, fresh, and it eliminates the need to toss bleach bottles. Tomorrow, my automatic liquid Chlorinator arrives because those jugs are heavy.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    The "Pinch a Penny" is also the cheapest I can find around $4.50 for 2 1/2 gal refill,but you have to pay to rent the container the first time deposit charge for a full one and Its just about 1/2 mile from the house.Also the MA seems to be the best price as well and they always have it in stock too.All the other places I tried to find it is always out of it around here. I have checked everywhere close by too believe me. I found out since moving here to Florida everybody uses a lot of bleach here for more things than the Pool. The mold and mildew is really bad down here!
    It's also fun just to take a sample into them sometimes to see how much their test will differ from mine now that I got my own test kit.
    6100 gal. In ground pool,1HP Pentair Superflo pump, 100 sq. ft. Cartridge filter , 3" tab dispenser, Aqua-Cal heat pump system ,Baracuda MX8 cleaner, in a Birdcage,Taylor K-2006 complete FAS-DPD chlorine kit.
    "Remember Folks Freedom Isn't FREE !!!"
