Results 1 to 9 of 9
Thread: Any opinions on resurface color with screen enclosure?
    Mar 2015
    Orlando, FL
    6
    Any opinions on resurfacing products and colors for a central Florida pool is appreciated. Will use a premium product. Only want to do this once.
    Contributing factors:
    1. New screen enclosure to be built
    2. Rectangular pool 3 feet to 8 feet deep
    3. Full sun mid day, some shade mornings and late afternoon, evenings
    4. Currently chlorine, may switch to salt after resurfacing
    5. Tile is navy blue and white
    6. Deck is currently off white, may be changed
    I think I like bright to medium blue, but could be swayed. Post your pool pics if you like.
    TYVM
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Any opinions on resurface color with screen enclosure?
    Hello,
    Welcome. I've got Diamond Brite finish, it came with the place. I believe it very similar to pebble tec finish. There's lots of info comparing Diamond Brite to Pebble Tec.
    for example: http://www.oceansrg.com/pool-resurfa...vs-pebble-tec/
    I think Diamond Brite is based out of Florida. I'd recommend you visit pools with both to compare what you'd like. Get some estimates from different contractors. I think that materials being similar, the finish comes down to the skill of the installer.
    Good luck!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    This is purely personal taste, and you should get what you really like.
    Welcome to the forum, and enjoy your stay!
    Essential Links:
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    You need to get black, because I want to see more pictures of black bottom pools.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2011
    Murrieta, CA
    2,360
    Black bottom pools appear so deep....
    Mar 2015
    Orlando, FL
    6
    I agree I should get what I like and I am getting professional estimates.
    Posted this just to see if anyone had a nice bright clean crisp blue they were happy with in a screen enclosure. If so, feel free to post some pictures.
    I am learning that a screen is just one of several factors affecting actual water color.
    J
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You're correct, everything around the pool has more effect than people realize. Lighter blues and lighter Greys will give you a crisp Blue water color.
    Essential Links:
    Mar 2015
    Orlando, FL
    6
    I've been looking at a lot of pictures of pools with screen enclosures. It appears that even a good old fashioned white plaster or white pebble tec or wet edge product will give a crisp blue look to the water.
    The screen enclosure seems to make the water look a bit darker. At least in pictures.
    Mar 2015
    Orlando, FL
    6
    Probably going with Pebble Sheen. White Diamonds, Aqua Blue and Blue Granite are still in the running.
    Back yard faces south. Pool runs east to west. Neighbor to the west has 2 tall trees that shade the pool in the late afternoon and evening. That shade plus the screen will probably make the water look darker than mid day with the sun overhead.
