Thread: Could epsom salts cause the pump to seize
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Is there any way using Epsom salts in a hot tub would cause the pump to seize? My tech seemed to think it was a no-no...after he replaced my 15-yr-old hot tub pump that seized very shortly after I'd added Epsom salt. So I've avoided it, but it could have been coincidental....
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Could epsom salts cause the pump to seize
    Pure coincidence in my opinion. That pump was getting ready to go no matter with the Epsom Salt.
    Essential Links:
    No, that doesn't make any sense. There are ways that epsom salt could aggravate some other pre-existing problem. For example, if you already had a shaft seal leak spraying water onto the bearings, epsom salt would have made that situation worse. But in that situation it would have failed in not too long regardless.
    Epsom salt, like regular salt, increases the corrosiveness of the water just a little bit. However, all of the components normally in contact with the water should be able to handle that no problem.
    Aug 2014
    Placentia, ca.
    12
    Just curios but how much did you put in? Just considering I need #300 of solar salt when ever I refill my pool I don't know what a little Epsom would do in the Jacuz but what do I know.
    18k gl IG pebble attached spa, Goldline aquarite T15, Hayward Superpump 2.0 hp, 500 sqft cartridge filter, Hayward H series 400,000btu heater. All new in 2002 except the pump.
