Thread: white calcium like deposit on pool cover. indoor pool
    Mar 2015
    Manchester UK
    1
    Hi
    Has anyone come accross this. A white calcium like deposit on pool cover. I ws told it was the result of algae built up residue after cleaning off the algae.
    Does anyone know of how to remove it? power washing does not touch it. http://easyhosting.net/poolcover1.jpg
    Thanks
    iavapool.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: white calcium like deposit on pool cover. indoor pool
    Welcome to TFP!
    Doesn't look or sound like anything algae related. Calcium would be a guess, but it could be most any mineral present in the water or pool chemical added.
    Can you chip a small piece off and add it to a little acid to see if it fizzes?
    To really give advice, we'll need a good set of test results. TA, Hardness, CYA particularly, as well as a description of what kind of chemicals you use in the pool for chlorination and pH adjustment.
