Thread: My 1st water test with new Taylor kit
    Aug 2008
    Delaware
    45
    I am so new to this pool testing I hope some one can give me some guidance.
    ph-7.6
    free chl.-5.0
    total chl..-5.0
    cc-0??
    ta-40
    calc. hardness-80
    temp-80
    Susi
    30X14 IG,Vinyl,13,800 Gal
    Hayward-Pro Series Sand filter(Rated flow75GPM/284LPM)
    SWG-Aqua Comfort,Polaris360 Auto Vac
    Re: My 1st water test with new Taylor kit
    You should raise your TA level. The recommended TA level with a SWG is between 60 and 80.
    I am not sure why you put question marks after the CC number. Having CC at zero is good. If you are unsure of the reading, feel free to ask and we can answer any questions you might have.
    Do you have a CYA reading? You listed all of the important numbers except that one.
    Aug 2008
    Delaware
    45
    I see now that a cc reading of 0 is fine,I questioned it earlier because I am somewhat overwelmed with the test kit.
    I checked the cya level twice because my kit tells me to add cloudy soln. to comparator tube until the black dot on the bottom disappears when viewed from the top. Well it never really disappears only is clouded over with the cloudy water. So I took a reading of 9. Can you help me with this? Thank-you.
    Susi
    30,403
    Susi,
    The CYA test seems a little backwards at first but it sounds like you are doing it right. If you have filled your view tube and can still see the black dot, your CYA will be much less than 20ppm.
    High CYA (of 80 or so, for example) will make the black dot disappear when the tube is lass than 1/3 full.
    So it sounds like you are doing the test correctly, you have less than 20ppm CYA, and you need to add some more to get your pool up around 60-80ppm
    Aug 2008
    Delaware
    45
    Dave,Jason,
    Thank you both for your help I will add what is needed and recheck my levels.
    Would love to start the summer over....I cannot believe how fast it went! 8)
    Susi
