Thread: Replacement for Aqua Lumin 2 Niche less light
    Dec 2007
    NW Georgia
    56
    I have searched the forum trying to find a thread on a replacement for the aqua lumen niche less pool light with no luck. Does any one no of a suitable replacement for this light?
    41K L shape Vinyl IG, 2.0hp Jandy stealth pump, 300lb sand filter, Autopilot Dig-220 SC-60 cell, Dolphin Oasis Z5.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Replacement for Aqua Lumin 2 Niche less light
    Sorry, I'm no help here but I'm giving you a bump incase it will help.
    Essential Links:
    Can you tell us more specifically what you are looking for? Do you need instructions on installing the replacement, or a suggestion for a different brand that will fit in the same place, or a vendor that sells parts for the Aqua Lumin 2, or something else?
    Dec 2007
    NW Georgia
    56
    I'm looking for a replacement led light.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by Simearl View Post
    I wish. The lights are ****. Pentair has completely failed with this product. I've had two, and the one I have needs replacing. Nothing else will mount to the bracket and nobody makes an LED bulb to replace the standard bulb.
    Dec 2007
    NW Georgia
    56
    Same here. I have two in my pool and both have failed. Short of draining the pool and cuttin a hole in the wall i dont know what im going to do. I dont want to go back with the same lights.
