Results 1 to 15 of 15
Thread: Please help me choose the right valve
    Apr 2012
    Mason, Ohio
    119
    These are the valves that I currently have for my deck jets:
    I need to replace one (and will probably replace all of them), but I'm not sure what the best options are. I've seen a lot of recommendations for Jandy NeverLube valves, but I'm not sure if they are over-kill for this purpose.
    Also, if anyone has recommendations on the best way to replace given this layout/design it would be greatly appreciated.
    Thanks in advance!
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    38,237
    Re: Please help me choose the right valve
    PVC valves stiffen up and sometimes leak and seize up. No problems like that with the Neverlube (or equivalent valves).
    For these deck jets, you could consider some of the PVC valves that use unions on both sides, then you could replace the valve part easily if you have a problem in the future.
    For a valve that is rarely turned, a ball valve can be ok. But I would want something better if the valves are turned often.
    Apr 2012
    Mason, Ohio
    119
    Thanks for the response. What are the NeverLube like equivalents that would be recommended?
    38,237
    The ones that look the same from Hayward or Pentair.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'll be honest with you and say that in time, those valves wont seal, the handles will break, or both. It will take several years most likely, but it will happen.
    Essential Links:
    Apr 2012
    Mason, Ohio
    119
    Quote Originally Posted by Patrick_B View Post
    Are you talking about the valves in my photo? You're exactly right. That's why I need to replace one, and will probably replace all. Jandy NeverLube seems like overkill, but it's not sounding like there are many options in between.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Yep it stinks. But it's an investment, in your time and not having to deal with it again in a few years.
    The appropriate Pentair valve costs roughly $25 on the Internet. It is a little more expensive than a ball valve, but hardly cost prohibitive. The Jandy version is under $45, more but not all that much more.
    Mar 2015
    Houston, Texas
    14
    Plus, the added benefit of the Jandy/Pentair/Hayward valves is that they can be easily rebuilt without having to replace the plumbed in body.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Mike_k View Post
    Yes, that's what I meant, and for all the reasons from other posters above. It really isn't much "overkill" if any.
    Essential Links:
    Jun 2012
    N. Georgia
    17
    Amazon had the Jandy Neverlubes for the cheapest when I replaced mine FYI. Good luck.
    IG Vinyl 16-18k gal, Intelliclor IC40 SWCG, Ranger 24" Sand Filter, Jacuzzi Magnum Pump 1 1/2 HP, Pentair GW9500 Kreepy Krauly Great White Pool Cleaner.
    Apr 2012
    Mason, Ohio
    119
    Thanks for all of the replies. Sounds like it's a good investment.
    Any tips on the best way to remove the old and install the new?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Get a good set of PVC cutters would be my suggestion, but perhaps you ca borrow a pair if you never will cut PVC on a regular basis.
    Go to a place with a large selection of PVC, like an irrigation supply house and get CLEAR primer. They might even rent you cutters, but I doubt it.
    Essential Links:
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    All the PB's that I interviewed in Houston all use Jandy Neverlube valves.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    Apr 2012
    Mason, Ohio
    119
    Thanks. I'll look into cutters. I saw a YouTube video where the guy used pool-specific PVC cement. Is this needed?
