Thread: Possible Algae?
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    Possible Algae?
    Been real busy and have not had time to brush pool. Now form dirt and other organic matter blowing into the pool, I have black spots in the water, mainly on stairs, swim out and some spots on the floor. It's hard to brush off with a steel brush, especially on the grout lines. When brushed off, it's leaves a green spot. Is this algae?
    Water has been balanced and real clear.
    If it is, do I kill off with bleach or algae treatment?
    Thanks
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Possible Algae?
    Sound like it might be black algae. You might have poor circulation in those areas so when you aren't brushing the pool this slow-growing algae (technically, a cyanobacteria) takes hold. You can SLAM the pool and brush the affected areas regularly during the slam to expose the roots to elevated chlorine levels and that should kill it off.
    Apr 2010
    Coral Gables, FL
    197
    Re: Possible Algae?
    Thanks. Yes, outset stairs is the worse area.
