Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: NUMBER OF LEDs
    Aug 2014
    NJ
    435
    NUMBER OF LEDs
    I have been reading a lot of threads about how many LEDs are needed in a pool and am wondering if I should add an LED (note that my pool was already gunited) My pool is 50 feet long and about 23 feet wide in parts. I have 2 LED lights facing each other (see pictures - hopefully they atatched) 50 feet apart. I also have a small Niche LED light in the Grotto (light kind of faces Sun Shelf). The Sun Shelf has two LED bubblers and there will be two LED Laminars behind the Grotto and rock wall.
    Do you think I need another LED light?
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    justinfrancisjudd's Avatar
    Dec 2014
    Temecula, Ca
    135
    Re: NUMBER OF LEDs
    I have 5 in my pool and its 46 by 23ish in parts
    not sure that it would be easy to add a light after the gunite that said
    2015 Build, Stonescapes Mini Pebble-Blue Sea, 46.5'x23', 9' deep, Paramount IFCS on steps and shelfs, 8' spa with spillover, Quartzite Flagstone Coping and Patio, 3" Suctions and Returns, 1 skimmer, 6 Jandy LED Watercolor lights, Baja Shelf w/ diving rock, 2x 2HP Jandy VS E-Pump, Jandy LXI 400K BTU Heater Cupro/Nickel exchanger, Cartridge Filter, Grotto/Waterfall/ Slide, Jandy SWG, I-aqualink 2.0
    38,267
    Re: NUMBER OF LEDs
    Are you getting colored LEDs or white? Some colors do not travel far in water so it can look pretty dark. Just depends on how bright you want the pool. Some people do not want it bright as it attracts bugs.
    I do not think it would be worth the hassle and expense to add another one.
    Aug 2014
    NJ
    435
    Re: NUMBER OF LEDs
    I am getting color lights.
    Thanks
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Re: NUMBER OF LEDs
    I only have 1, and I regret it. I wish I did a second one in the shallow end, and you're pool is about 60% bigger than mine. I'd say at least 3, maybe 4.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Aug 2014
    NJ
    435
    Re: NUMBER OF LEDs
    Thanks everyone.
    If I added one, where should I add it? If I had thought about it earlier, perhaps below the rock ledge on the left. But if you look at the top picture, the ledge on the left will be filled with Rocks, and to put a light below the ledge may be difficult because they will need to drill through two feet of croncrete. I'm not sure if putting one on the Sun Shelf makes sense as I will have two LED bubblers there. I'm also not sure there is enough room from the top (as the Sunshelf has only 8 inches of water).
    Any ideas?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Re: NUMBER OF LEDs
    You don't really have any good placement options that don't involve going through 2' of concrete. With your other light on the bump out in the deep-end, your darkest areas will be to both sides of that light.
    If you did add one, I'd suggest in the alcove to the left of the sunshelf.
    That said, it won't be "dark" (except maybe on the deeper colors) but certainly not bright. A white pool finish would make noticeable difference versus something with a lot of color.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Biggbotti's Avatar
    Nov 2014
    Ny
    112
    Re: NUMBER OF LEDs
    I have a black pool with 3 pentair 5g color and some colors are dark. Red is the worst
    34x48 40,000 gal mt lake concrete wall vinyl lined pool,gli 28 mil blk granite liner w/sure-step, pentair easy touch 8 w/screen logic,pentair fnsp 48 filter,2 pentair intellichlor vs pumps, pentair intellichlor ic60, 3 pentair led intellibrate 5g lights, 4 pentair magic stream Laminars, 12 ton moss rock waterfall
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    Re: NUMBER OF LEDs
    Sorry to hijack, but what software are you using in that 2nd picture? I'm designing my own pool in AutoCAD (2D), and would love to get something going in a real 3D pool modeling program (if not too expensive, obviously) to help visualize things better. I wouldn't need all the detail in my AutoCAD plans, just the basic surface elements. Any suggestions?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Re: NUMBER OF LEDs
    Looks like something I got when I used PoolStudio.
    https://www.structurestudios.com/web...e-pool-studio/
    Aug 2014
    NJ
    435
    Re: NUMBER OF LEDs
    That picture was from my PB. I don't know what program they were using.
    Aug 2014
    NJ
    435
    Re: NUMBER OF LEDs
    My PB said at this point I can only add a Nichless low voltage light (like the one I am getting in the grotto). Do you think it makes sense to add one on my Sun Shelf (even though I do have two LED bubblers on there). I am worried that the Sun Shelf, which is higher than the other parts of the pool, may not get enough light.
    Also, would it make sense to add one on the wall directly across from the Sun Shelf?
    Is adding a low voltage light worth it ($1100 a light).
    Thanks
    Aug 2014
    NJ
    435
    Re: NUMBER OF LEDs
    One other question in addition to the above. My PB now tells me that I can't put a light in my Tanning Shelf because it is too shallow (8 inches). Does that seem right?
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    Re: NUMBER OF LEDs
    Quote Originally Posted by grottoguy View Post
    I just discovered these the other day: http://www.pentairpool.com/products/...lights-454.htm. They're specifically designed for shallow areas (i.e. tanning ledges, benches, etc.). Ask your PB if these would be ok, and let us know what he says. I'm hoping to be able to use these in my 9" tanning ledge.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Re: NUMBER OF LEDs
    Documentation says top of the lens must be at least 4" below normal water level. Lens diameter looks to be 3" max from one of the pics. So 9" water depth would appear to be no problem.
    Aug 2014
    NJ
    435
    Re: NUMBER OF LEDs
    The documentation didn't indicate the diameter of the lens (which is strange since I would have expected them to state the minimum depth needed). The problem with this product for me is that the lights won't work with my Aquilink.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Re: NUMBER OF LEDs
    Correct that it doesn't seem to mention the lens diameter but it does show the fixture in the same diagram with 2" PVC which is where my guess came from. Too bad about your controller interaction. Seems like a perfect solution for those with Pentair controls.
    Matchless1's Avatar
    Jul 2014
    Baton Rouge, LA
    258
    Re: NUMBER OF LEDs
    Quote Originally Posted by bmoreswim View Post
    The Pentair lights (believe it or not) is the main reason I will be using ALL Pentair equipment (controller, pumps & SWG), except Jandy valves.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,805
    Re: NUMBER OF LEDs
    I can see that. If there's a differentiating feature, that's a great reason to choose one of the top brands over another.
  20. Back To Top    #20
    Aug 2014
    NJ
    435
    Re: NUMBER OF LEDs
    I just found what seems like an equivalent light. Savi lights which are now owned by zodiac (jandy). I will see if they can go in my Tanning Shelf. Any thoughts on whether I should add nicheless low voltage lights elsewhere in my pool. My PBA said he can't add the more powerful lights any more since he did the Gunite already.
