Results 1 to 7 of 7
Thread: Help. Pressure is high on gauge
    Mar 2015
    Bonifay,Fl
    3
    I was going to start cleaning my pool to get it ready. It is green. No chemical in it yet. I have ran filter all winter at least 4 hrs per night. Today I put my creepy vac on to start working on the bottom. I notice the pressure was over 40psi, so I figured I better backwash and rinse. When I first did backwash noticed some sand came out I let it backwash for several minutes and then rinsed for several minutes. I let it vacuum for about 30 minutes and checked the pressure was back over 40 psi so I again backwashed but after several minute no water was coming out the waste line. So I rinsed again and then put the dial back to filter and let it run again pressure went right back to 40. so I tried backwashing again it bring the pressure down to 30 but nothing lower. But pressure goes right back up. I change the sand last year. I have very strong water return to the pool. Any suggestion as what might be going on?
    13k Gals, AG, Jacuzzi sand Top dial multiport, Aqua EZ 1.5 hp 1speed, creepy vac.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help. Pressure is high on gauge
    Welcome to TFP!
    Does the pressure go to zero when the pump is off? What pressure do you see when the multiport is set to recirculate?
    Mar 2015
    Bonifay,Fl
    3
    No it stayed at 20. When I turn the multiport to filter it jumped to 35. Could it be as simple as my gauge is messed up? We did have some freezing temps at night. But why would the flow completely stop during backwashing?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Just remember, the filter will not clean a green pool. You need to read and follow the SLAM - Shock Level And Maintain procedures. Anything less is just going to drag out the process of getting your pool clear.
    Support the site
    38,284
    If the gauge does not drop to 0 when the pump is off, then it is bad. I would recommend the large glycerin filled ones like tftestkit.net sells ... much better than the junk typically found locally.
    Mar 2015
    Bonifay,Fl
    3
    Thank you for recommendation on the gauge. I will be ordering today. I also will be looking into a testing kit. All I have is test strips. I added swimtrim to start working in the algae. Running filter continuous. I know I have no free chlorine. I will read the SLAM.
    38,284
    Well, I highly recommend the TF-100 from tftestkit.net ... order that while getting your gauge ... add a SpeedStir if you like very helpful gadgets
    And since you need to SLAM, the XL option is a good idea.
