Thread: Borate
    Borate
    Need some help finding a reliable Borate testing kit. Can someone give me a recommendation?
    Thanks
    27100 gallon in ground Pool/Spa, SWG, Pebble Sheen-Aqua Blue, (All Pentair Equipment) Pentair VS Pump, Cartridge- filter, build completed Dec. 2013, Houston, Texas
    Re: Borate
    Nothing is really great for measuring borate. For swimming pools you don't really need much precision in your borate measurement, so we mostly use the LaMotte borate test strips (despite their problems).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Borate
    Agreed, the small amount of precision you need isn't justified by the trouble and expense of a true kit for this test. It's really rare, but this is one exception where we will say it's "close enough"
    Essential Links:
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Borate
    When I added borates and when I drain and refill, I just use Pool Math to calculate how much to add, and assume it's right. I've only tried to measure the borate levels once, (not very accurately).
    chiefwej
