Thread: Direct sunlight 7-8 hours per day and effect on CYA/chlorine
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    I understand that the more CYA I have in my pool the more chlorine I have to add, but what effect does the 7-8 hours of direct sun I get per day have on the CYA Chlorine ratio. Right now the my CYA is at 50 my chlorine stays between 3 and 5 all of the time...Even in late August I still test daily. The CYA Chart shows that at CYA of 50 my minimum should be 4ppm and my Target should be 6ppm...with the direct sunlight that I get does that effect my minimums and target numbers in relationship to the CYA?
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    30,408
    Re: Direct sunlight 7-8 hours per day and effect on CYA/chlorine
    No.
    If you are maintaining 3-5ppm, then you are doing things exactly right regardless of the amount of sunlight you receive.
