Results 1 to 7 of 7
Thread: tstex filter question
    Houston, TX
    1,102
    Angry tstex filter question
    Quote Originally Posted by kimkats View Post
    I LOVE my sand filter! It is SO much easier than my old cartridge one. The pump does all of the work with the sand filter.
    The cartridge one it wet and time consuming.
    Kim
    Kim,
    I have a Hayward Cartridge System and it is brand new so I am w it for awhile.
    Can you expound on why you like the sand filtering system better, what were any issues you had w the cartridge filter?
    Regardless of what filtering system, consistent and timely maintenance is the key. I clean out all of my skimmers daily and the pump baskets all the time. the less debris in them, the less stress and more efficiency on the pumps and filtering system.
    Thanks
    tstex
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    Re: Very disappointed in Pentair. Next step?
    When it is time to clean is when I love the sand filter.
    Cartridge filter cleaning-
    -turn off pump
    -close all valves going to filter
    -open plug on filter (water tends to spray at this time)
    -allow filter to drain
    -get the filter ring loose and off (I had a hard time but found if I hit the right lightly with a rubber mallet I could get it off)
    -take top of filter off
    -take cartridge "holder oner" off and put in a safe place
    -take cartridge out (I tended to get my feet wet with this part as the filter came up and out it dripped water all over)
    -Put cartridge on something off of the ground (I used a cement block)
    -spray cartridge over and over and over making sure to get between each and every pleat. I would also turn it over and redo it to make sure I got it good and clean. (I got VERY wet doing this and the whole area was wet and messy)
    -put cartridge back in
    -put holder oner back on
    -put filter top back on AND make sure it is seated (this was very hard for me for some reason)
    -put ring back on and tighten
    -close plug where water ran out
    -open plug on top
    -open all valves going to filter
    -wait until water starts coming out of the plug on top (another time to get wet)
    -close plug on top
    Cleaning a sand filter:
    -turn off pump
    -turn filter handle to back wash
    -turn on pump and let it run until the water runs clean
    -turn off pump
    -turn filter handle to rinse
    -turn on pump for 3 bursts of 30 secs each to settle sand back down
    -turn off pump
    -turn filter handle to pump
    -turn pump on
    Note the lack of "real" work I have to do for the sand filter compared to the cartridge filter.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Take all that ^^^^ up there and multiply times 4 for the 4 cartridges in my filter. I am very happy with the job my cartridge filter does, but it is more work. Especially for us because we have a lot of trees that put a LOT of stuff in the pool in spring and fall. If I ever decide to buy a new filter it will be sand.
    Houston, TX
    1,102
    Kim & Pook - thx for feedback...we have very little trees if any, so more air-borne than anything...I will go thru the drill for the next X yrs and whenever it is time to renew, I'll know the drill - thank you
    Re: tstex filter question
    Just to give a balancing opinion: cartridge is great because it doesn't waste water backwashing. If you get a large cartridge filter you only need to clean it once a year, which really isn't that big a deal. And cartridge cleans up the water more quickly after algae and other problems compared to sand.
    That said, they are both good choices.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Here's another data point, tstex: I have had zero pressure increase in my cartridge filter after using it for the last 4 months since my pool was installed. If it's anything like the pool in my last house, I'll do a filter cleaning once a year whether it needs it or not! Even though it's a PITA, it's not bad to only have to worry about it that infrequently.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Houston, TX
    1,102
    IF I only had to do the many things I do once a year, I would be a very happy person...I wish my pool panel breakers would only trip once a year...or, see my PB only once a year...Thanks for the feedback
