Results 1 to 8 of 8
Thread: New Construction - Heater Help
    Mar 2015
    Patterson, CA
    12
    Good Afternoon TFP!
    My family (wife, 4 yr old, 2 yr old) are finally getting started on the long awaited project of building an in-ground pool *YEA!!
    Now that we are taking this dream serious, a number of options are coming out of the woodworks that i never thought about before. Thankfully there are sites like this one that can hopefully help answer my questions.
    1. To heat or not to heat? I live in the central valley in California, so the temperature is pretty mild most of the time. Today's high is going to be 75 degrees with the 80s expected next week (hello global warming). I was looking into getting solar heaters, but since the front of my house faces south and i do not want the panels on the street side of my roof, i would have to put the panels on the north facing roof. So now i am stuck with the dilemma of going with less than efficient solar panels, a gas heater, or nothing at all. I am leaning towards nothing at all, but with two young children, i would like them to be able to enjoy the pool as much as possible. So what do i do? would it take a long time for a gas heater to warm up my pool? would solar panels on the north side of the roof still be efficient enough? Or have the kids suck it up and swim in a cooler pool? Pool is approximately 13,000 Gallons
    2. I am planning on using the Pentair IntelliChlor and if i do not get a heater, the Pentair IntelliChem. I am already getting the IntelliTouch System so i can interface the pool with my Crestron System. Does that sound like a good plan? I really do not want to be measuring chemicals everyday and would like to keep the pool as safe for my children as possible.
    3. Sand filter or Cartridge filter? The pool builder gave me the choice, but forgot to go over the difference
    Thank you very much for any help!
    Eric
    Re: New Construction - Heater Help
    Welcome to TFP!
    Do you want to extend the pool season, heat just for nice weekends in the spring/fall, maintain a higher than normal water temperature during the main season, etc? Heating gets expensive if you do very much of it. We only heat for the occasional nice weekend in the spring/fall. Solar will be less expensive than anything else for constant heat, but isn't going to be able to do beautiful weekend heating at all well.
    We don't recommend getting the IntelliChem, or any other ORP based chemistry automation system. ORP based control adds cost and complexity, more things to maintain and more things that can break. Simple percentage based SWG control is just as good in an outdoor pool and much more reliable. No kind of automation will eliminate daily pool chores, though they don't need to take very much time at all.
    Both kinds of filter are good. Sand uses more water, is slower to clean up algae, but is by far the least amount of work.
    Mar 2015
    Patterson, CA
    12
    WOW!
    Quick response and nailed all three of my questions. Thank you very much Jason. I guess we will go with the gas heater since the thought of "beautiful weekend heating" sounds like exactly what we had in mind.
    Is there anything else that i should be thinking of adding to my pool systems? Currently the builder has spec'd out the following
    Pentair Intelliflo pump
    Pentair Intellichlor
    Pentair Sand or Cartridge filter (still not sure which to get)
    thepoolcleaner 2 wheel suction cleaner
    The pool will have Wetedge Satin Matrix.
    Thanks
    Eric
    That all sounds good. I do recommend getting a large filter, larger than most builders tend to default to at least. Larger filters can go longer between cleanings/backwashing and just slightly improve system efficiency.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    I LOVE my sand filter. I had a cartridge one last time. It worked great BUT was a lot more work for me than the sand one is.
    Heater+kids=more fun time in the pool while they are younger.
    I am sure you have thought of this but the Mom in me has to ask-----------fencing and safety features on the doors and gates for the kids?????
    We would love to see some pictures of your yard and pool!
    Have you ordered your test kit yet? I ordered mine before I ordered my pool LOL I wanted to make sure I really could do it. It is very easy to do.
    Kim
    Mar 2015
    Patterson, CA
    12
    Sounds good. Big Sand Filter it is
    Yes we have alarms on the doors and a removable gate around the pool. Here is the current video from our builder.
    https://www.youtube.com/watch?v=bKnjf49XUMg
    I love technology!
    Eric
    Jul 2012
    Tallahassee, FL
    30,476
    Love the video!
    Great job on the door alarms and fence!
    Kim
    Mar 2015
    Patterson, CA
    12
    It looks like this is the sand filter i will be getting:
    http://www.pentairpool.com/products/...ilters-183.htm
    They are recommending the TR100 filter which will do more than 4 turns a day. Pool size is about 13,000 Gallons.
    Thanks Everyone
