Thread: Low to no FC, no CYA, high pH......where to start?
    Apr 2014
    Mobile, Alabama
    75
    So I'm trying to get my pool ready for the season. I've been adding liquid chlorine (10.5%) over the winter since "closing" to keep the water clear. The water started to get a little cloudly last week so I SLAMed it and it's sparkling clear again, but I noticed my FC dropped quick. Low and behold, my CYA is next to 0. I did the black dot test and filled that tube up without making the dot disappear. I've got chlorine, CYA, and muriatic acid, but I wanna know what I should add first? I figure I should add CYA first as this will protect any chlorine I add and help lower pH. What'cha think?
    Kevin T
    16' x 32' Vinyl Liner Grecian Pool. 20,000 Gallons. Sta-Rite SuperMax 1HP Pump (PHK2RA6E-102L). W. Cooper Ranger Series 25" Sand Filter. Dolphin Nautilus Plus.
    Re: Low to no FC, no CYA, high pH......where to start?
    First, lower the PH to the 7.6 to 7.8 range. The CYA will lower it a little more, but get it in range first.
    Then start working on raising CYA.
    Add a minimum of 2 ppm of chlorine once a day through the raising CYA process, even if it all vanishes.
