Thread: Need help with leaking pool
    Jul 2014
    Honolulu, HI
    3
    I am having a leak problem with my 20k gallon tile pool. I contacted my local pool repair shop and they recommended letting the water leak down until it stops to determine where the leak is. Looks like it is at the skimmer level where the lines attach to the skimmer box. I also did the food coloring test and looks like one of the 2 skimmer holes might be the culprit. The problem is I cannot see exactly if there is a crack or a hole in the line. If I can see where the damage is I was going to try pool putty to seal it. Any advice on how to proceed?ImageUploadedByTapatalk1425832299.505008.jpgImageUploadedByTapatalk1425832345.923916.jpgImageUploadedByTapatalk1425832366.330713.jpg
    30,431
    Re: Need help with leaking pool
    Not sure what advice you are looking for. You need to positively identify the leak, of course, and then pool putty or any type of epoxy might be a good fix, depending on how much movement there is in the repaired area.
    If there is movement at the crack, it will be very difficult for the fix to be anything but temporary.
    Are those ceramic tile around the waterline?
    Jul 2014
    Honolulu, HI
    3
    Yes those are ceramic tiles. I was hoping to get advice on how to pinpoint the leak inside the skimmer line as it is tough to see in there and feeling around the area didnt show anything definitive.
