Thread: Cracked tile under water line 1 year old
    Feb 2014
    Sarasota
    43
    I have a tile which is located under the waterline it is right above the quartz plaster, plaster comes right up to this tile. The pool was built less than a year ago. You really can't tell unless you know it's there. Any advice on what I should do. Are there any fixes other than drain down pool, replace and repair plaster?
    Thanks
    11,000 gallon gunite kidney pool. Krystal Krete blue pepper interior finish. Pentair Superflo VS pump, Pentair Clean and clear RP 100 filter. Goldline blue essence with T-15 SWG. Savi sol LED. 4 deckjets
    Re: Cracked tile under water line 1 year old
    Often the most practical thing to do is to ignore it until it is time to re-plaster. Most pools are built so that water getting behind the tiles is not a real problem. And replacing the tile so it looks right is a major project that requires re-plastering if you want it to look good as new.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    If the pool is that new, will your pool builder take care of it? I believe it's usual and customary for a 1 year warranty on PB workmanship. (Or is that must my wishful thinking?)
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's going to be a real problem replacing it now. As jason mentions, it will probably look better just leaving it as is. I would feel the same if it were mine, but getting it to look right is not easy, and with the pool full...
    Essential Links:
