Results 1 to 8 of 8
Thread: power consumption of a SWG
    smeestu's Avatar
    Oct 2014
    Thailand
    67
    " EMAUX SSC50T when running at 100% it will use approx 15 amp at 220V-230V"
    This is the email i got back from Emuax today when i asked about the power consumption of there 45g /hr SWG as i understood reading various figures it should be in the range of about 300w power usage .Im going to put a UPS/regulator in line as the electricity here in Thailand is not very reliable and the supply goes up and down . But from what they have sent me do i understand it corectly that the power consumption is going to be 3300w so 3.3Kw
    volts x amps=watts ? .Does anyone else know the consumption of there units or have i missed somethig here dont know too much about electric myself .If so a standard 500w UPS which i was thinking of using would be no good for this
    Home built Concrete pool tiled 100% 6M X 12M 1.1-1.6 m deep 93,000 litres 24,500 US gallons
    Emaux SB15 1.5hp pump ,Emaux v700B Sand Filter with Zealbrite
    Emaux SSC50-T 45g/hr swg ,Jacuzzi chlorine Tablet Feeder
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: power consumption of a SWG
    Yes, volt x amp = watts. There is no way SWG draw 3300 watts. My Pentair IC40 SWCG manual is not completely clear about power consumption. But, it looks like max output is 165-292 watts from the power supply and max draw of the cell is 220w. So, the 300w reference seems to be correct and a 500w ups will be fine.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by smeestu View Post
    Throw in some "heavy water" and you might be close to initiating cold fusion with all that energy!
    (All apologies to Pons and Fleischmann....)
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    DFW, TX
    24,516
    lol. When I see Fleischmann i think margarine.
    To OP,
    I found two more references that further confirm, one says that it draws 1amp at 220v and another that says it draws 240 watts. The sub-300 watt consumption is accurate.
    The power is converted to lower voltage dc current. Probably somewhere around 12 to 20 volts dc. The 15 amps is probably correct for the power going to the cell. The power would be the amps x the voltage going to the cell.
    Support the site
    DFW, TX
    24,516
    This is what the pentair manual says for the intellichlor power supply. 110v at 2w or 220 at 1w.
    IntelliChlor Model IC20, IC40 and IC60
    Input: 95-130 VAC, 50/60 Hz, 220 Watts (2 AMP) or 220-240 VAC, 50/60 Hz, 220 Watts (1 AMP).
    Output: 22-39 VDC @ 7.5 AMPS maximum from the Power Center.
    Note that US SWGs such as Jandy, Pentair and Hayward are typically in the 6 to 7 amp range at about 24 to 28 volts dc going to the cell. However, Australian units seem to be more variable in their voltage and current going to the cell.
    Support the site
    smeestu's Avatar
    Oct 2014
    Thailand
    67
    Thanks for all the replies thought it wasnt right and wanted to check in the "real" world that was the info sent from Emaux support i can not find any information about the transformer voltage at the cell but thats what i asked them thats what they sent back .Looking at what info is out there seems to be generally around the 300watt area for a 45g/hr cell so i think a 500w UPS with a regualtor will do . Im guessing no one else is running a UPS or a Emuax Salt cell on here.
