Results 1 to 8 of 8
Thread: issue with CYA and no chlorine detected
    Jul 2014
    CA
    4
    Ch - None showing on the test, I can't get the color to change at all
    PH - 7.5 (could be a 7.6, kinda close)
    Alkalinity test - 140ppm
    Calcium hardness - 420ppm
    CYA - 100 or above, the test doesn't specifically state what it is above 100
    so my issues are obviously two fold. first off, the chlorine isn't showing. i use the puck chlorine in a floater. it doesn't really seem to be reducing much. i put a 3 inch tab and after about 2 weeks there is still a good part of it left.
    i had some issues last year and had to have my pool partially drained (3/4th's or so) and refilled. this was back in july of 2014 or so. how can i get my CYA down? i've read that you may need to refill the pool to get cya down but it just seems strange that i would have to drain/refill the pool twice in less than a year. something else must be happening or that i'm not doing.
    any advice?
    Pool Size = 17,738 gallons, in ground pool, plaster material
    Cartridge filter. I'm not certain of the brand. Pump is Pentair 340039 SuperFlo.
    I believe the pool was BUILT in the 70's. I don't know with 100% certainty but it is definitely not new. I'm using the Taylor K-2006 test kit.
    I have an automatic pool vaccuum.
    Re: issue with CYA and no chlorine detected
    The only practical way to get the CYA level down is to replace water.
    With CYA as high as it is now, it is unlikely you will be able to resolve the situation before lowering the CYA level. So getting CYA down is the first priority. Once you have CYA down to something more reasonable, it is time to SLAM the pool, see the description of SLAMing in Pool School.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If you are using trichlor pucks exclusively to provide chlorine, then that is what is causing your CYA problem. The pucks contain a lot of stabilizer. Every puck you add increases the CYA and finally you get to the point where there is so much CYA, that the FC is simply not sustainable.
    Until you stop using pucks as your primary source of chlorine, then the problem will continue to repeat itself.
    This is why TFP recommends to use either Liquid Chlorine or a Saltwater Generator to make it. Neither add other unnecessary chemicals to the water such as Pucks, or Powders do.
    Quote Originally Posted by antemasque View Post
    any advice?
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Jul 2014
    CA
    4
    drats. thanks for the replies fellas. i don't think i can drain the pool/refill for some time. there are restrictions in my city that say you can only do it a certain amount of times (on account of us being in a drought), and i just did it 6 months ago. i usually don't start using the pool for swimming until may or so, so maybe by that time i can do something with it. just frustrating that in only 6 months its out of control again.
    i'll look into the liquid chlorine. any advice on where to get the best price? seems a bit on the high side from what i see online but maybe a local store has better deals
    Richard320's Avatar
    Jan 2010
    18,984
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Another option, although kind of costly from what I've read here, is to use a Reverse Osmosis (RO) service. Its kind of like dialysis for the pool water. You won't have to drain then
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    How many 25 lb buckets have you used. For your size pool. Every 25 lbs adds just shy of 100 ppm of CYA. That with no water replacement and probably added to the CYA that was already in the water. You can see how it adds up fast. TFP is about learning to accurately test and only adjusting what needs to be done. That's why we push liquid chlorine "household bleach" or SWCG. Good luck and ask questions. That's what this place is all about.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
