Results 1 to 7 of 7
Thread: AquaNaut 400 vs Poolvernugen?
    Mar 2014
    Los Angeles
    21
    Does anyone know the difference? They look similar and both now made by Hayward.
    Re: AquaNaut 400 vs Poolvernugen?
    Hayward bought Poolvernugen. The AquaNaut is the first cleaner based on the Poolvernugen to be released under the Hayward name. I don't know what, if anything, they changed.
    38,473
    I saw one released by Pentair that looks almost the same too ...
    Jan 2013
    Long Island, NY
    184
    Quote Originally Posted by JasonLion View Post
    The price! Pool Cleaner is $80-$100 less.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Mar 2014
    Los Angeles
    21
    Wow....now there are three that look the same or similar. The original Cleaner (poolvernugen) , the Hayward AguaNaut, and the Pentair Warrior. I like the handle on the Pentair unit and the ability to take off the top to clean out debris that has gotten stuck. The Original and I believe the Hayward versions come with three sizes for the throat opening which may be of use. If you filter is dirty you can throat down the size and still get some cleaning I believe.
    The Bing's Avatar
    Jul 2014
    Boston - South Shore, Massachusetts
    5
    Quote Originally Posted by Newz54 View Post
    As far as I know, The PoolCleaner does/did not come with interchangeable throats; the AquaNaut does and they can be used with The PoolCleaner (would need to order as replacement part(s) through Hayward dealer).
    22K gal, IG gunite, kidney shaped, built circa 1987. Hayward Sand Filter S244T with Vari-Flo XL multiport control valve. Hayward Super Pump 1.5 hp. TFTestkits TF-100. SpeedStir. The PoolCleaner 2x suction. Municipal water.
    May 2015
    Kennesaw, GA
    29
    An interchangeable throat may be a big advantage - particularly for vinyl liners. I discovered that with my vinyl-lined pool, the Poolcleaners suction was not strong enough to maintain enough traction for the wheels' contact with the pool. I am now very pleased with my Poolcleaner, but had to do some experimenting with the tires to get it really screaming amazing. You might read my final post on the thread I started on the subject - Poolcleaner Tires - Any experience with Vinyl??
    Leo In Kennesaw, GA
    Older 40x20 rectangular pool
    38,000 gallons
    Vinyl In-ground - Buster Crabbe
    Pentair Chlorinator - Salt - SWG
