Results 1 to 17 of 17
Thread: Very disappointed in Pentair. Next step?
    May 2014
    SW Washington
    61
    Angry Very disappointed in Pentair. Next step?
    In leiu of a string of angry smilies, I will attempt to calmly explain my predicament. Given this is my first filter maybe I am just overreacting and this is no big deal?
    I ordered a Pentair SD80 from Amazon. It showed up today in absolutely, unequivocally the worst product packaging I have ever seen in my life. The filter head was not secured in any fashion and was allowed to move freely within the box during shipping. The plastic parts to the head were damaged on arrival. The rest of the parts (bag of screws, clamp assembly, pressure gauge, etc) were also loose so I am unsure if I have everything. All the laterals (except for one ) were screwed onto the piping assembly within the tank so it rolled around during shipment. Because I had one free floating lateral in the box I was concerned it had been screwed on to begin with but came off during the shipping process. When I tried unscrewing the rest to take the whole assembly out and inspect for damage I couldn't get one unscrewed because the blue glue used on the piping had run over in excess and seeped around one lateral so it is permanently stuck. Is any of this normal?
    Do all Hayward filters show up like this? Should I care that I can't remove that one lateral? I really don't want to have to send this back and I know Amazon would take it no questions asked but assuming I buy another Hayward is it going to show up like this again?
    My helper- the small box the head was sitting on looked like the head started out inside it at one point but it was never taped so it came out and rolled around.
    14k Gallon 24' x 54" Signature RTL , 1 hp 2 speed Pentair Optiflow, 350lb Pentair SD80 sand filter, 2" leaky plumbing, a Zodiac G3, and my TF-100!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Very disappointed in Pentair. Next step?
    I'm not sure Pentair is to blame for this. It's more a shipping issue of bad handling.
    You have no idea what happened after it left Pentair and went through all the channels before it reached you.
    Essential Links:
    May 2014
    SW Washington
    61
    True, but I would never expect to throw 60 pounds worth of loose equipment into a box big enough to fit a small family and assume it would show up as I sent it. Even if FedEx is partially to blame for the damage to the box I think if Pentair routinely packages items like this it shows a lack of attention to detail. And I am not thrilled with the lateral being inadvertently glued in either.
    Oh well, this is exactly the reason I wanted to order things plenty early. I hope the rest of the shipments are trouble free.
    Jun 2011
    Long Beach, CA
    2,790
    Send it back and hopefully the next one will be packaged right. Sounds like it was an open box or something and not a Pentair issue.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Tell Amazon to take it back. Unbeknownst to you, Amazon will hold the shipper accountable for the costs associated with this damage. Unbeknownst to the Amazon, the shipper will hold the seller/manufacturer accountable for the damage if they determine that improper packaging was used. The US B2B system is very efficient and the responsible party will end up paying the bill. If Pentair is ultimately responsible and this happens frequently enough, they will have to address this issue.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    May 2014
    SW Washington
    61
    Quote Originally Posted by JayBauman View Post
    I think that was what I needed to hear I was worried I would send it back and the ultimate problem would never get fixed. I did see on the reviews that one person had the same problem I did with the shipping but their items didn't get damaged (luckily). I am not usually one to complain or want to get into it with customer service but this flipped a crazy switch in me. I think because it seems so painfully avoidable!
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    There's also a nuanced take on the scenario I outlined above. While you purchased your filter from Amazon, you didn't say who actually fulfilled the order. If the actual seller buys a lot of these units, they might come to him as a palletized shipment...which would be meant for his use and not for re-sale. The pallet and associated packing materials allow for robust shipping with actual product boxes that may not be so tough. If he then sells you one of these boxes (which would not really be suitable for direct shipping), then I can envision the situation you have described. In this case the seller (and not Pentair) would be liable.
    Regardless of the situation, the right party will be held to account for the damaged equipment and you'll eventually get a new, working filter.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You can send it back easy with Amazon. I've had a few things show up broken. No problem.
    Essential Links:
    May 2014
    SW Washington
    61
    Thanks for talking me off the ledge. You have a great insight on the inner workings of online shopping We have a few big box stores close to us but that's about it so I do probably 90% of my shopping online for non-grocery items. Although I guess I did just buy cheese online the other day....Anyhow, I have come to expect my daily visits from UPS to bring my pretty little Amazon boxes all buttoned up and pillow-packed so nicely.
    Well, given the opportunity to 'do-over' would everyone still recommend a filter that size for a 12k gallon above ground pool? That was **huge**! Any other brands/models that would do better?
    That filter is a good choice. A larger filter has advantages. Personally, I would get something with a side mounted multi-port valve, however that would be noticeably more expensive.
    May 2014
    SW Washington
    61
    I am so reluctant to re-order the same thing and have the problem again. A little part of me is holding some resentment towards Pentair. Hhhh! Decisions.
    Pentair SD80 3.5sf, 75gpm $346
    Sta-Rite Cristal-Flo II, 3.15SF, 70GPM $299
    Hayward S244T, 3.15SF, 62GPM, $290
    Jacuzzi Laser L250, 3.3sf, $339
    *or* I could do something crazy and get a cartidge filter Hayward C1200 $319
    I promise, if I just get a smidge more advice I will be done asking things for at least the next two hours
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I think you made the correct choice the first time.
    I am a big fan of pentair. And I am a growing fan of sand filters.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,572
    I LOVE my sand filter! It is SO much easier than my old cartridge one. The pump does all of the work with the sand filter.
    The cartridge one it wet and time consuming.
    Kim
    Casey's Avatar
    SW PA
    10,453
    I love my DE.
    Feb 2015
    Florida Panhandle
    12
    I was wondering who wrote that review! I appreciate the feedback. It has kept me from going through with the purchase of this very same filter despite its low price of $329.99... Great news is you purchased from Amazon and they have awesome customer service. Most likely they will email you a shipping label and send someone out to pick it up for you. If you end up getting a replacement SD-80 from Amazon please update, I would love to know how it looks. I slept on the Hayward 27" S270T when it dropped in price and has since shot up to $407. Keep holding on to hope that the price on 4.9 sq ft units will drop here soon but I doubt it.
    IG vinyl 18' x 36' oval ~20k gal SW pool built in 1999 (liner new 11/2009) Hayward Ecostar 3400VSP (7/2011) Hayward SwimPure Plus SWG (3/2011) w/ Hayward T-15 cell (8/2015) Pentair Eclipse 26" sand filter #589301 (sand 3/2011) Aquabot Turbo TJet (5/2012) Newbie currently updating some plumbing and looking for a great deal on a new sand filter!
    May 2014
    SW Washington
    61
    As an update I re-ordered the same pump but instead of going through Amazon directly as the shipper I chose one of their sellers. I have no clue if I will have the same problem but I figured it would be a little experiment to see if they all shipped in the same packaging. I think I was about $348 for the Pentair SD80 after taxes (free shipping). Heres to hoping!
    Also, is 12.99$ a decent price for 50lbs of pool sand? Our Lowes and Home Depot don't carry any filter sand but I see Ace Hardware does. It is HTH brand if that makes a difference.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by linzjane88 View Post
    That's a good price, and about norm for here. It's #20 sand and that's what you need. It's just as good as anything else pool sand wise. Good luck on the shipping. If it's broken, they'll make good on it.
    Essential Links:
