Results 1 to 7 of 7
Thread: Balboa Control panel she no work
    Mar 2015
    Ottawa/Canada
    4
    Hi, new to the forum.. My hot tub jets do not activate when I push the buttons on the control panel. I did a bunch of googling and came to the conclusion it was the control panel.. But then a little more digging and maybe its just the overlay? I see they sell overlays.. Is it common that the overlay buttons stop working but the control panel its self is still fine?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Balboa Control panel she no work
    Welcome to the forum Joe!
    I can't answer, but giving you a bump so someone may see and give you the one you need. Good luck, and enjoy the forum.
    Essential Links:
    Mar 2015
    Ottawa/Canada
    4
    Quote Originally Posted by Patrick_B View Post
    Thanks for the Bump!
    I had the same problem. Try turning the breaker off for a full minute then turning back on.
    17000k gallon IG vinyl kidney, iaqualink 2.0, Hayward cartridge, 1.0 hp VS Jandy, fusion 2 SWG, Toronto
    Mar 2015
    Ottawa/Canada
    4
    Quote Originally Posted by junglejetjay View Post
    I tried unplugging in for 5 minutes or so.. I assume that would have the same effect as flipping the breaker? Only have the controls work.. I can turn the temp up but not down, I can turn the lights on and off but can turn the jets on.. The jets do seem to work though
    Hey joe, that's the exact problem I had with my bullfrog A6 tub. Like I say, I turned the breaker off for a minute and it fixed everything. Any warranty left?
    Mar 2015
    Ottawa/Canada
    4
    Thanks for giving me hope found
    The problem. . I pulled the panel and two wires are fried.. I'll have to replace the panel.. at least I didnt have to spend 150 bucks for an estimate
