Results 1 to 16 of 16
Thread: Adding LED lighting to waterfall
    Mar 2015
    Brentwood
    3
    Has anyone added lights (LED strips?) to a water feature? I have a few LEDs surface mounted, but would like a colored "glow" under the water
    Jan 2013
    Friendswood, TX
    320
    Re: Adding LED lighting to waterfall
    I just have underwater LED lights in mine. No color change.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Maybe look at boating accessories too. The make all kinds of colored underwater lights for docks and boats.
    Mar 2015
    Brentwood
    3
    Paul, Any pictures? What brand or any other information on how you added them after the build would be helpful.
    Steve
    Jan 2013
    Friendswood, TX
    320
    Not good ones. I will take some tonight and post!
    ~Paul
    Jan 2013
    Friendswood, TX
    320
    The led's are underwater ones I found at Home Depot. They are $30 each and 2/3 fail. The look is good but the quality of the lights suck.
    I want to use strips though so that I can catch the lower fall before it hits the pool.
    ~Paul
    christied48's Avatar
    Aug 2013
    Allen, TX
    89
    Hope u can see this image. Builder put in some low voltage fiber optic lights.. alson on the stairs.. they dont sync to the rest of my LEDs but its fine to us.
    24K gallon IG Stonescapes, Jandy VS pump, cartridge filter
    Aug 2013
    Allen, TX
    89
    Aug 2013
    Allen, TX
    89
    Aug 2013
    Allen, TX
    89
    Aug 2013
    Allen, TX
    89
    Color changing Fiber optics - fiberstars? They bend all around.. however you want. We have 2 at top inside of grotto.
    Aug 2013
    Allen, TX
    89
    Aug 2013
    Allen, TX
    89
    Sorry it wasnt saving.. then they all saved
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    haha!
    Hi Christie,
    The first couple posts by every new user must be approved by a moderator. This keeps the spammers out.
    Sometimes it might take a little time to find your posts waitining for approval.
    By the way, Welcome to TFP! Great looking pool you have!
    Quote Originally Posted by christied48 View Post
    Divin Dave,
    Aug 2013
    Allen, TX
    89
    Ahh.. how funny! Thanks Dave! Been learning/researching here since 2013 and probably would have lost our sanity if we hadnt followed others builds. Just seeing what others struggled with between delays and quality control helped us climb back off the ledge more than a few times. Also helped us to stand our ground that we werent just being super picky.. just need you to do it right, please. Here is a day shot.. appreciate the help, welcome and compliment. This site is a lifesaver for real!
    22,000 IG Pool, Spa, Jandy 2.0 Stealth VS, LXi400N Heater, Jandy 460 filter, grotto waterfall/slide
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Awesome!
    Divin Dave,
