Results 1 to 7 of 7
Thread: Enlarging a spa
    Enlarging a spa
    My wife wants us to have our jacuzzi increased in size. It is built into the side of our pool. How difficult of a job is it to expand a spa? I'm assuming the existing plumbing can be used but the rest of the spa will need to be demo'd and then rebuilt bigger.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Enlarging a spa
    Welcome to the forum.
    Thats not a question we see every day, and I don't know if I can say more than the obvious. This will be quite a project. No chance you can live with the current size? You may not be able to access the existing plumbing without destroying too much of it. That's just the tip of the iceberg I'm thinking.
    Essential Links:
    Re: Enlarging a spa
    Quote Originally Posted by Patrick_B View Post
    I can live with it but I'm not sure about my wife. One idea I had was to covert the spa into a decorative waterfall and just build a new spa next to the pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Enlarging a spa
    A friend of ours expanded their gunite pool, made it bigger and deeper. PB cut the wall out, probably about 1/3 of it. Drilled holes in the old wall for rebar and the rest looked like a regular pool build, rebar, plumb, gunite, etc. This was 2 or 3 years ago and all is well. It can definitely be done.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Enlarging a spa
    Quote Originally Posted by austin_guy View Post
    That might be an idea. Don't be surprised if just adding a spa runs about 15k, depending on what you want. As with most things though, with enough time and money you can do pretty much anything like this.
    Essential Links:
    Re: Enlarging a spa
    Expanding a built-in spa is certainly possible, but it tends to get very expensive. First they have to cut out roughly half the spa, replace nearly all of the spa plumbing, pour or spray concrete for the new spa, and replaster the entire spa.
    Jun 2011
    Carlsbad, NM
    172
    Re: Enlarging a spa
    Another option might be to use a prefabbed fiberglass spillover spa. It could be installed in a different location or over the filled original.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
