Results 1 to 7 of 7
Thread: Can Solar Heaters Be Plumbed Into Pool Fountain?
    Oct 2013
    Los Angeles, CA
    87
    I as wondering if any one has installed solar heaters and plumbed their return into a fountain? If not could it be done?
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Can Solar Heaters Be Plumbed Into Pool Fountain?
    No reason it couldn't, but running water through a fountain is a good way to cool it off. Kind of defeats the purpose.
    Oct 2013
    Los Angeles, CA
    87
    I was planning on running it on its own return but instead of making a new return hole I was just going to plumb it over the liner straight into the pool
    That is fine, aside from the pipe potentially being in the way.
    Oct 2013
    Los Angeles, CA
    87
    If the return pipe was outside of the water, would this act as a vacuum release?
    Yes. Depending on how high off the ground your panels are that might be a little bit low for a vacuum release. Panels on a one story roof will be fine with that. But there is the possibility of issues with panels on a two story roof and the "vacuum release" down at ground level.
    Oct 2013
    Los Angeles, CA
    87
    Alrighty Thank you for the help the panels are only 9 feet high
