Results 1 to 12 of 12
Thread: BBB for Beginners
    Mar 2015
    Sugar Land , TX
    424
    BBB for Beginners
    I to just got a new pool! Well we begin to fill tomorrow. Been lurking until now and studying alot online. I think the TFPC / BBB method is for me. So my first question is do I not need the chlorine tablet feeder they installed? Is it possible to use the TFPC method along with the tablet feeder or am I defeating the purpose of TFPC?
    Message moved by Divin Dave - TFP Moderator
    Orlando, FL
    690
    Re: BBB for Beginners
    I would only use the feeder when you are found to be gone for an extended time. For daily chlorination, I say, just stick to TFPC.
    Welcome to the forum!
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi rphpool,
    welcome to TFP,
    Stick with the TFP method of using chlorine. Using primarily the tabs can lead to undesirably high CYA levels.
    Hope this helps!
    Divin Dave,
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    BBB for Beginners
    Welcome to TFP !
    To be able to practice our methods your going to need one of these Test Kits.
    I use the TF 100. It's the best value.
    The pucks have their place like when your on vacation and can't manually dose with bleach if you go that route.
    If you haven't already, make sure to take some time and take a look at these two articles from Pool School.
    ABC'S Of Pool Water Chemistry
    How To Chlorinate Your Pool.
    Any question you have ask away.
    Jeff
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum rph,
    Having the In-line chlorinator would be fine for limited use as Jeff mentions. It's only when you use it as your permanent and sole source of chlorine that you get into trouble. If you want it, it wouldn't defeat the purpose of what we teach.
    Mostly what that amounts too, is learning what different chemicals are for, what they do, and what side effects adding them brings to your pool. By a pretty good margin, the most common problem we see here is people with high Cya/over stabilized pools. That happens because people used pucks and "shock" as the primary chlorine source which adds that compound. It's by far the most common side effect problem we see.
    We stress the basics first, learning, understanding, and testing. Begin with the ABCs in pool school, and work your way from there.
    Essential Links:
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Here's how I'm using my inline puck chlorinator....I filled my pool last December. My SWG isn't very effective with the cold temperatures we've had this winter, so I'm using pucks until whichever comes first:
    a) water gets consistently warm enough for SWG; or
    b) my CYA gets up to my target value
    Since I get my CYA from the pucks, I haven't had to purchase any stabilizer. In fact, I plan to use my inline feeder to keep my CYA at target levels throughout the summer as I replace water that gets splashed out. With a house-full of kids and dogs, we lose a lot of water in addition to the regular Houston evaporation.
    So pucks-n-inline feeders aren't completely evil. Just mostly evil.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    That tablet feeder is just another tool in your arsenal to properly manage your pool. Gonna be gone for a few days--------use it. Need to raise CYA a bit--------use it.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Quote Originally Posted by JayBauman View Post
    I like this idea to get CYA and chlorine from pucks when it is cold. I am buying bleach and stabilizer at the moment. I will try this next.
    But, seriously, how can water evaporate with 200% humidity? A bunch of my outlaws live in Houston and I think the air fills their pools.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Quote Originally Posted by pooldv View Post
    I'm sure that during the humid summertime there is a net flux of water from air into the pool. The water level probably goes down when the various Gulf Coast bugs come out at night to slake their thirst. Have you seen the size of the insects that we have around here? They're probably draining my pool dry. Sometimes I'm worried that my pug might get carried off by one of those things!
    Mar 2015
    Sugar Land , TX
    424
    Thanks for all the replies. It is now 2 weeks since first filling pool and I have not been able to get Ph below 7.8 for any length of time ( I add about 16-20 oz per day ). IT JUST KEEPS RAINING !!!. I guess this is normal because of dilution. My pool builder has said no chlorine yet because Pebble Sheen is curing and still "shedding". The water is crystal clear though! I have an elavated spa that has a water fall. Do you think the aereation it causes is not letting my Ph go lower?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Quote Originally Posted by rphpool View Post
    yes, the waterfall aeration causes the pH to rise - but it is probably the curing plaster that is causing more of it. It will continue during your first year before it settles down
    Support the site
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Rphpool
    Solar Blanket, Well Water, Borax Added. 68°
