Results 1 to 7 of 7
Thread: Chemical Storage Areas
    Jul 2014
    NJ
    11
    So, I need a little help from somebody with a better memory than me. I know it is illegal to have a chemical storage area that is separated by a permeable barrier (like an indoor fence/gate). You need a solid barrier or the rest of the area is considered chemical storage as well. I know this, but I cannot remember the law or even if it is a federal or state thing (state is NJ). Anybody know where I can find it?
    Two IG pools, 40,000 gallons each
    One plaster, One concrete
    Sand Filters
    Pentair 100c filters
    Re: Chemical Storage Areas
    Are you talking commercial or residential? And storing what?
    For a residential pool, nothing you are remotely likely to have on hand is going to trigger the special storage area requirements.
    Jul 2014
    NJ
    11
    It's not commercial or residential. Borough pools run by the local government. So for the most part, same regulations as commercial/public pools.
    Sand Filters
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Something I have thought about for myself was one of those outdoor storage sheds they sell at Costco. Have you considered those? They are all wood sides, so I believe that would be meet any requirements. Also, they have those large Rubbermaid sheds at the BBS such as Lowes & Hm Depot, but those could possibly warp w/ extreme heat/sun, but I believe it would take years for that too happen. The wooden ones they sell at Costco downside they have to be painted every so often to protect the wood. But, they will last.
    I know out in CA here, the ones they sell at/through Costco were part of one of those road shows. So, while it may not be a regularly sold item, they should have it every so often.
    19k gal IG plaster, built '70s, probably resurfaced in '80s-'90s; Blue Haven Hayward filter C4520BHMB (Filbur FC-1275 cartridges); Hayward MaxFlo sp2302 VSP 1.5hp; 6 solar panels 288. sq. ft. total (142"x47.5" ea.) on 1 story hm; Pentair Compool LX220 Solar Controller; FlowVis flow meter; Maytronics Dolphin S200; AG 300 gal AquaTerra spa; TF-100 & Speedstir; gone: Pentair Challenger 3/4 HP 1 speed; Polaris 280
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Since its a burough pool available to the public I presume, and people work there, it will most likely be subject to at least OSHA regulations. Possibly others as well, depending on what is being stored.
    The types of storage areas, lockers, buildings, etc are also subject to the type of chemicals/ materials stored in them.
    Im not quite sure you will find your answer on the TFP forum, but I wish you luck in finding it.
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It may fall under Haz Com CFR 1910 regulations then. If it does, we can't advise you properly. You'd better check with your local agency in this case.
    Essential Links:
    Jul 2014
    NJ
    11
    Thanks for the ideas on places to look. And don't worry Patrick, I already know what to do, and already did it. I just was trying to remember where the law is because the current project I'm working on at these pools is "Stop breaking laws." It's a project that got held up with old management. I'm trying to cite all the recreational bathing code and other laws in my list of all the stuff I'm fixing.
    Sand Filters
