Thread: variable speeds always trip GFI breaker?
    Aug 2014
    So cal
    17
    Was reading a old post-"Does an Intelliflo variable speed pump need a GFI breaker?" http://www.troublefreepool.com/threa...-a-GFI-breaker
    I was told by a warranty pool repairman that GFIs cause probles with variable speed pumps, something about constant rpm changes that trips GFI every day. He said that since my light has GFI I should be ok.
    Any thoughts?
    16k pool/spa clean & clear filter Polaris auto cleaner ecoStar pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: variable speeds always trip GFI breaker?
    I'm sorry, do you mean the pool light?
    Essential Links:
    While variable speed pumps tripping GFCI breakers does come up now and then, it isn't a common problem. Most installs work just fine.
