Thread: Pool Surface Renovation Needed in East Hawaii-- Any Sources?
    Mar 2015
    Pahoa, HI
    3
    I need to resurface my in-ground gunite shell pool since the mosaic tiles we used originally are coming off. Because of where I live (remote area on an island with small population) there aren't many sources or choices I can find for contractors, so I'd love some input or leads on companies I might contract to do the work. I'm wondering if I will need to fly them here from the mainland and give them a Hawaiian vacation in the mix to make it happen! Thanks, R
    27,000 Gallons; IG; Gunite shell w/glass tile surface (problematic, as tiles are detaching); Hayward sand filter; Sta-Rite pump, single speed; constructed in 2000; Taylor FasDPD testing; (Notes: Hawaii has a lot of rainfall, which here especially is a bit acid, so I've found that using chlorine bleach is pretty good for sanitization because it naturally is a bit alkaline, so constantly adjusts for that fact.)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pool Surface Renovation Needed in East Hawaii-- Any Sources?
    There has to be someone out there doing tile pools. However, I can learn fast.
    Essential Links:
    Mar 2015
    Pahoa, HI
    3
    Yeah, I wish it were all that easy! I think I'm going to end up doing a plaster surface, as there's a guy that does that here...
