Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: What brand of robots would you recommend?
    Feb 2015
    Frisco, TX
    21
    Quote Originally Posted by Divin Dave View Post
    My only thought is like Dave S. say, the polaris suction line in the wall of the pool is just one more place that could potentially spring a leak some time down the road.
    Your friend who went throught two of them may not have had one of the better robots with a proven track record.
    Robots have improved drastically in quality in the last few years and continue to do so. I have pretty good feeling that mine is gonna last a few years. But if I only get 3 out of it, I will be happy.
    What brand of robots would you recommend? Thanks!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: What brand of robots would you recommend?
    Hi Sliptool,
    A lot of us here at TFP would recommend the Dolphin line of robots. They have a pretty good reputation.
    Also, the Tiger line of robots by Hayward are highly thought of.
    There are lots of options available on robots, and options mean $, so do some googling and get a good feel for whats available out there.
    Of course any of us here will try to answer any specific questions that you might have.
    Quote Originally Posted by sliptool View Post
    Divin Dave,
    Feb 2015
    Frisco, TX
    21
    Thank you Dave! I'm about to sign a contract with the PB but I was wondering if it was better to do a Robotic cleaning system or the pressure cleaning with a booster pump (Polaris 280). The size of the pool will be 18' x 36'.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Sliptool,
    Everyones personal preference is different. The 280 is a good cleaner, but old technology.
    the pump it requires is very loud, and it eats up electricity. The 280 has a bag that collects the stuff it sucks up and lots of folks find the bag messy to clean. But its does a good job of cleaning!
    The Robots are dead silent. They run on 24V and use almost no electricity. I like that because it means I can run my robot a LOT, and not see my electric bill go up just because I want my pool clean. And most robots use pleated filters that are a breeze to clean.
    Also one more item to mention. The 280 requires a dedicated pipe to the pool. And as lots of folks will attest to.. one more penetration in the pool wall for a pipe, is just one more potential place that a leak could occur somewhere down the road.
    I just dont think you can go wrong with a good quality robot. My personal experience is with the Dolphin. I love the thing!
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I know I am a broken record on this one, but I say Robot every time. I would not want to be without mine.
    Essential Links:
    Feb 2015
    Frisco, TX
    21
    Thank you for the advise guys... but what about convience? My understanding is the 280 you just throw it in the pool and only take it out to clean it. Can you do the same thing with a Robot? Or do you have to put it away every time you use it? Also, do you need to clean the pool everyday in the summer? or since it cleans better than a 280 you dont use it everyday?
    Thanks and sorry for all the questions.
    Jun 2011
    Long Beach, CA
    2,788
    The 280 can be left in the pool 24/7 and gets removed to clean it or go swimming. I would not leave a robot in the pool 24/7.
    Each pool has its own characteristics for how often it needs to be cleaned. Some pools need cleaning every day, while others can go a long time before they need cleaning, it depends on how much stuff gets in to the pool.
    A good robot will scrub the entire surface which will help reduce the need to brush the pool, while the 280 will require the pool to be brushed down weekly.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    What's your pump run time? I like having the robotic cleaner. I've got a smart pool nitro, when it dies, I'm thinking of getting a Dolphin from Maytronics.
    http://www.maytronics.com/robotic-pool-cleaners
    They cost a little more but have gotten consistently good reviews.
    I use my cleaner every few days. I just installed a pool cover so I'll use it a little less often. I have left it over night several times and it hasn't had any ill effects. The cleaner doesn't have any issues with the pool cover, so that's a plus. I posted a video of my pool cleaner in action on this link:
    http://www.troublefreepool.com/threa...into-1-minute?
    Feb 2015
    Frisco, TX
    21
    Quote Originally Posted by bobodaclown View Post
    Thanks Bobo for the feedback. I actually dont have a pool just yet! I am about to sign the contract with the PB this week; however, I was trying to figure out if it would be better to do a Robot cleaning system and forgo the extra pump, plumbing and the Polaris 280.
    Apr 2011
    Murrieta, CA
    2,360
    I would forgo the extra pump and plumbing and get a robotic cleaner.
    Oct 2007
    Parkland, FL
    752
    I leave my robot in the pool all the time, I don't think dolphins are the best, but they win when you can buy parts for reasonable prices and install at home.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Feb 2015
    Cypress, TX
    54
    I keep seeing how the booster and pressure cleaners eat up electricity. Can someone advise what the difference is roughly for an average pool? My choice is a pentair robot or the racer. At 7.5 cents a kwh is it really that significant of a difference?
    18k gallon IG gunite/pebblesheen with 3ton moss rock waterfall, 8 ft 12" raised wall & rock accents , 42sq ft 12" raised spa w/ 6 jets & cascading stacked stone waterfall, 3HP Intellifo VS pump,
    420sq ft Pentair cartridge filter, 400,000 BTU Pentair Gas Heater, 1.5HP Whisperflo water feature pump, 1.5HP Silencer Spa Blower, 3 intellibrite lights, EZTouch System 8
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    Sliptool, just another vote for the robot. Have a Dolphin M4. It does a great job, easy to dump top-loader baskets, and theoretically can be left in pool if you want.
    Ricky, can't speak to your question exactly but the beauty of a bot is that you can clean with pump off if you're trying to reduce pump time.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by ricky12 View Post
    I don't know about this one, but most pressure side boosters are fed by and therefore require the main pump to be running.
    This is another downfall of pressure cleaner/booster pump systems.
    Essential Links:
    Feb 2015
    Cypress, TX
    54
    So the booster pump requires the main pump to be running to operate a pressure cleaner?
    Feb 2015
    Frisco, TX
    21
    My PB is quoting me $1,450 for a Dolphin Supreme M5 and only giving me a credit of $600 for the Polaris 280 and Booster Pump. Good deal? Also, does the M5 have good reviews?
    Jun 2011
    Long Beach, CA
    2,788
    I'm guessing the $600 is fairly close to his cost of parts for the installation for the Polaris 280. The M5 is a top of the line cleaner and you can only get it through a local supplier, no internet sales. The M5 looks like it is about the retail price.
    Jun 2014
    Rogers, AR
    424
    The M5 is my first choice. I called three pool stores in my area and they all are asking $1,800-2,000. If I could get one for $1,450 I would grab it.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Oh wow, I bought mine last spring. Surely they haven't gone up that much!
    Try West Tx Pools in Abeline Tx. They will ship it UPS to you. At that price, it would still be a good deal with shipping to AR. Mine was right at 1500 delivered last year.
    Yes, they are fed by the main as there is no suction line from anywhere else.
    Essential Links:
  20. Back To Top    #20
    Feb 2015
    Frisco, TX
    21
    Thank you everyone for your feedback... I think I will go with the M5. Also, this review of the Dolphin Premier http://youtu.be/rOZMebaXztA helped me make my decision. I thought it would be nice to share it.
