Thread: Liquidator feed issue
    Jun 2014
    Dublin, CA
    6
    So I have had the liquidator for almost a year now and love it. But lately I've noticed some low chlorine levels.
    I check the chlorine level of the pool and its next to nothing today.
    I check the chlorine level in the water on the top of the liquidator and its almost zero even after adding 6 gallons yesterday.
    I give the tank a stir, and the chlorine level came way back up.
    Any idea why the chlorine isn't mixing properly? Am I doing something wrong
    30k in ground fiberglass pool with cartridge filters. Dublin (Bay Area) California
    22,548
    Re: Liquidator feed issue
    It sounds like you have something consuming the chlorine as it's introduced into the pool, and not a problem with the LQ (Liquidator).
    The chlorine concentration at the top of the water level in the LQ vessel should be very low. There should be a distinct line between the bleach and the water in the vessel. The bleach slowly dissolves into the water on top and is then dispensed into the bulk pool water as the pump runs.
    I suggest shutting the LQ down and running an OCLT to see if you have something consuming the FC.
