Thread: Cover pump recommendations.
    Greetings All,
    I have a little giant 1700 cover pump. It cavitates constantly and only works every once in a while. I have tried everything with this pump, and am ready move on. Looking for a replacement. I have a coverstar automatic cover over a 16k gallon in ground pool. Just looking for a reliable pump that does what it is supposed to do.
    Thanks for the help!
    15'x4' Metal Frame Intex (3yrs old) 16" 2650gph intex sand filter, TF-100 testkit
    Re: Cover pump recommendations.
    Best of luck. I have tried four different brands. One brand works very well, but rarely lasts even one season, another falls over and stops running once a week, the third gets clogged with debris way too easily, and so on.
    Mar 2011
    441
    I have had the least issues with the Wayne cover pump....
    http://www.amazon.com/Wayne-57729-WY...yne+cover+pump
    20X40 30,000 gallon gunite pool
    Quote Originally Posted by JasonLion View Post
    Yep, very frustrating. I may stick it out with this one. I will try the manufacturer again for some direction, but that have not been very helpful.
    Quote Originally Posted by racket View Post
    I have looked at this one. Has good reviews, but it it pretty expensive. I have even thought of not using a submersible and just running a hose with a trap on it on the cover.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I have this exact one from Amazon. Only used since last fall, but I have zero complaints. It's done very well with debris too. It will fall over, but this has happened only a couple of times.
    Essential Links:
