Results 1 to 14 of 14
Thread: What's in those Mineral Springs bags?
    Jul 2008
    Solon, Iowa
    170
    I'm a new pool owner (15X30 ABG Lomart) with a Mineral Springs (Goldline AcquaTrol I believe) SWG. First, this forum and been a wealth of knowledge - so here's a big thanks to everyone involved!
    The PB started it up with a chlorine shock, and then added the Mineral Springs salt (Beginnings). They gave me the Mineral Springs Renewal and told me to add 1 1/2 cups once a week. Thus far (running since mid-June) I've been tickled with how great the water quality has been (sparkling clear all summer), with minimal work on my part to keep the chemistry balanced. The solar cover (one of those bluetop/silverbottom diamond bubble jobs) stays on day and night except when someone swims (but I'm wondering if on sunny days the pool would warm faster with the cover off?).
    My FC stays in the 1-5 ppm range with my filter running about 9 hours/day with the cell set at ~40%. My unit reads about 2800 ppm salt (but other tests suggest it is low by about 300 ppm - I just ordered AquaChek salt strips thanks to info gleaned from this site). Here's what I'm curious about. My pH is staying in the 7.7 range but I haven't added any muriatic acid since start-up in mid-June. Why is that? Are there dry acids in that Renewal stuff (there must be borates because my test strips show good levels)? My TA is high (150) and I've just fitted a 50 foot 'soaking' hose (the kind with the little holes so it acts like a sprinkler) to my air compressor so I can get it down to the 70-90 ppm range before I close it for the winter. Is the high TA the reason for the more stable pH?
    I'm wondering if I should abandon the Mineral Springs stuff and maintain my chemistry by adding whatever substances I need separately. I don't like not knowing what is going in, the excellent results notwithstanding. The cost of the Renewal bags don't bother me, it's the lack of understanding of what's in there (OK, I'm a professor and scientist, so I like to know how these things work).
    Thanks in advance,
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    Re: What's in those Mineral Springs bags?
    Welcome to TFP!
    The Mineral Springs products contain a mixture of salt, borax, and CYA. In addition to being quite expensive, they don't allow you to adjust each of those levels separately.
    The borates are helping to buffer your PH. Presumably that is why your PH has been relatively stable despite your slightly high TA level.
    Jul 2008
    Solon, Iowa
    170
    Thanks, Jason. Starting next season I'll abandon the combination products and monitor/regulate these chemicals separately.
    Once again, thanks for a fantastic forum. These pools can be quite intimidating for people like me who have never owned a pool before.
    Kelly
    Aug 2008
    Hebron, CT
    79
    I am also new to this site. Great site! I have had a Salt Water pool for almost 3 years now. My pool company instructed me to use Renewal as well and I have done so. I was wondering if these bags are providing any true benefit? My water quality has been excellent since being a pool owner so I shouldn't complain, but these bags are $13 each and it adds up. Do you see value in continuing to add this product?
    22,500 gal Lagoon shaped inground pool, vinyl liner, Hayward 4800 DE Filter, Hayward 1.5 HP super pump, Aqua Heat Pump, Nexus Pure SWG, Dolphin Triton PS, Hebron, CT
    I don't see any point in buying Renewal. The individual chemicals are available far less expensively separately. The "magic" ingredient in Renewal is borates, and you can simply use 20 Mule Team Borax as a source of borates instead.
    Aug 2008
    Hebron, CT
    79
    Thank you!
    Aug 2007
    MN
    3
    How much borax would I need to add. Everyone allways say to add borax but never how much.
    Justin
    20x40 IG Vinyl Liner
    1.5 HP Pump (Pentair)
    4 Cartridge Filter (Pentair)
    400k BTU Heater (Pentair)
    Mineral Springs (SWG) Bio Guard
    Polaris Vacuum w/Booster Pump
    Under Track Automatic Cover (absolutely worth every penny)
    2 Skimmers
    3 Return Jets
    2 Drains
    2200 sqft of Stamped/Textured/Colored Concrete
    Diving Board
    Beer, Beer, Beer, Fun, Fun, Fun
    Oct 2007
    Philadelphia, PA
    86
    11x27 in ground, vinyl pool
    ~12,500 gal
    PAC FAB (Pentair) Pinnacle 3/4 hp pump
    Pentair 24 sq ft DE filter
    One skimmer, one return (no main drain)
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    As a Mineral Springs SWG owner as well, let me throw my $.02 in here! Thanks to the fabulous folks on this forum I have NEVER used Renewal in my pool. It was just installed this past Spring. I don't have a clue what the PB used on start-up as I wasn't there; but I can tell you that since then, nothing but a little borax, a little bleach and a little muriatic acid has been added. My pool has been sparkling all summer and still is! From the beginning, all I have done is taken my readings every week with the TF kit offered here and plugged those numbers into Jason's pool calculator. Whatever adjustments it told me I needed to do, I did. That has been so very little; it has absolutely surprised me to no end. I have spent around $40 this whole season with half of that still sitting in garage unsued as of yet!
    So, yes, there is something else you can use!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Mar 2007
    Coastalish 'down easter'
    4,160
    Kelly, these guys have given you the best advice!! Use your Mineral Springs unit as if it were an Aqua Rite and add the other chems as needed
    ps - I'd like to say 'hi' to Karen - hope all is well, maybe there'll be a Jimmy show in Nashville next year
    Luv& Luk
    -Ted
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Hijack in progress!
    Awwww....Hi Waste! If it hadn't been for you back in the Spring, I might have gone more crazy than I am! Boy, Nashville sure is due a Jimmy show! I think I'm having withdrawals! I had actually gotten a little routine going before the weather turned cool too soon of floating around the pool listening to the Sat. night concert wherever he was. It was pretty cool! Dang weather put a stop to that!
    Okay..sorry Kelly! Anyway..listen to Waste and "the boys"...they know their stuff!
    10,700 gal IG vinyl
    2 skimmers
    Jul 2008
    Solon, Iowa
    170
    And you can bet I'll be following this advice. I'll be closing the pool in a few weeks and next spring will see me using borax, solar salt, muriatic acid, and bleach as needed to supplement my SWCG. So long to the expensive Mineral Springs bags.
    Kelly
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Good for you! You won't be sorry. I NEVER thought it would be this easy!
    10,700 gal IG vinyl
    2 skimmers
    Jun 2017
    Maryland
    139
    I'm adding to this existing thread for posterity and sharing information.
    I canned the Mineral Springs chemicals this year.
    Last year was my first pool year and i simply continued what the previous owner was doing. She opened the pool before I moved in so I purchased the chemicals and paid for start up.
    I looked at the bill and it was $1200 in chemicals and $450 for the opening (they actually charge $100 to take the cover off and put it in the bag). My Friend's company that is all part of the opening.
    I thought this MSDS was interesting on the Mineral Springs Renewal.
    http://www.hydropool.com/downloads/M...newal-msds.pdf
    2nd page has the ingredients.
    Dry Acids
    Boric Acid
    CYA
    So at the beginning, my Chlorinator had a hard time keeping up. PB just said to throw in a couple more bags of the Renewal and crank up the SWG.
    I went back 2 weeks later with samples and it was the same story. This went on twice.
    The regiment was to throw in 2 of these 4lb bags (mind you, these are $15 a bag) into the pool each week. Yes. $30 a week
    I then went to a store by my work and the lady said I was low on salt and to put in 3 bags. After that, SWG was keeping better but not that great.
    Eventually it was better and the SWG was keeping up.
    in Hind sight, I think the extra bags was just to get the CYA up. I went in late Aug and the CYA on the print out was 80 (Who knows what it really was). At that point, My SWG was not having problems keeping up at I think 20% or 40%, I did not keep notes.
    Long story short, I"m off the Mineral Springs cool aide. I never had a problem with water quality I would say, but I am feeling much more confident managing my own water this year.
    25,000gal IG Concrete , Purchased Property 6/1/17 Pool Built 2008, Well Water
    Multi Port valve, DE filter, Intellitouch FW1.100, Intellichlor IC40 , Intelliflo VS2, Waterfall on a Jandy Compool
    Polaris 280 on 3/4HP Booster Pump. Screenlogic2. Mobile Touch Remote. Former Mineral Springs Customer
