Results 1 to 13 of 13
Thread: Testing Question
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    154
    Testing Question
    I have a hard time distinguishing colors when using a test kit. Last year was my first year of having a pool; I had a cheap test kit and used the strips that came with the build, but really didn't have a good grasp on what was correct after doing the testing. I mainly relied on the SWG readings and had zero issues. I'm the only one to do the testing, so asking someone else isn't really an option. Is it worth it to put more money into a more expensive test kit? Another issue I had was where do you do the readings...if they are done poolside the colors look differently b/c of full sunlight, vs. doing the test in the shade or in the house.
    Thanks!
    Sent using Tapatalk
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Testing Question
    Welcome to the forum!
    Yes it's worth it. When you consider the protection it offers on such an expensive investment, it virtually less than pennies. Test strips are unreliable at best. Do get a good kit, it's really essential to maintaining good control of the pool.
    Testing is best done in a well lit area. Results won't vary but Cya, is a tiny bit different in terms of lighting.
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Testing Question
    +1 to what Patrick said. Having an accurate way of testing your water, understanding what those results mean and what to do or not do with the results, will make your pool maintenance very easy. Do yourself a huge favor and get one.
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Absolutely its worth it.
    We would recommend either of the test kits at www.tftestkits.net The TF 100 even though slightly more expensive, will provide the best bang for the buck.
    Recommend to also refresh yourself in Pool School. Start with the ABCs. The basic knowledge of the chemistry and a test kit and you will be good to go.
    Divin Dave,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    YES it is SO worth it to get your own test kit!
    One thing you can do is do the tests and take a picture of them. Post them and we can tell you the readings. Do that until YOU can "read" the colors on your own. I go as far as holding the white plate up behind the test tube to make I can see the colors without interference of backgrounds.
    Welcome to TFP!
    Kim
    Jul 2014
    Hickory, NC
    154
    The white plate behind the tubes makes sense, thanks for that tip! I don't mind buying the kit or doing the testing, but having problems distinguishing colors is my biggest issue. Are the color results easier to distinguish on a more expensive test kit?
    Sent using Tapatalk
    ~ TF-100 test kit
    Jul 2012
    Tallahassee, FL
    30,638
    They are MUCH better with the drop test kit like we all have. Then strips are NOT good. The colors are not true and have a wide margin of error.
    We have been able to helps others that have trouble with colors by looking at the pics they posted and telling them our readings. After a while they were able to read their tests on their own.
    Kim
    38,521
    Did anyone mention that the only test where the color matters in the recommended test kits is the pH? The rest of the tests require you to count drops until the color changes or the CYA you pour until you can not see dot. Much more accurate than tying to match colors.
    Aug 2014
    Northern IL
    4,615
    No, no one did. I'm glad you chimed in!
    App: You will find the pH will be easy enough to discern within recommended ranges.
    May 2014
    Clarksburg, WV
    331
    I was going to say that.
    For the main test, (FC)....The water turns pink....You put drops in until the pink goes away. There are no "shades" of pink so to speak. There might be dark pink and light pink, but its either pink or clear. When its clear, you're done.
    The only one that is tough is the PH like Jason said. And I think everybody has trouble sometimes determining what shade red the water is.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Jul 2014
    Hickory, NC
    154
    Awesome, thanks everyone! I don't need shades of any color...lol!! I will look into ordering a kit!
    Sent using Tapatalk
    ~ TF-100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Order the kit. You won't regret it !
    Jeff
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,110
    If you go to TfTestkits YouTube channel there are videos showing each test in there entirety. Helps you see just how simple the tests are.
