Results 1 to 17 of 17
Thread: First ever battle with algae
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Hello! So it rained all day yesterday here, and it's not unusual for us to have quite a bit of dirt/sand in the pool after a big rain, but this looked different. I tested and everything tested OK, but I still felt like this was a little more than the usual. I ran the vac yesterday afternoon when the rain stopped thinking it was the normal sandy mess, but woke up this morning to just a tinge of a green cloud in the deep end. The screen looked extra clean, so I think this fun dropped in from the cage - yay.
    I started adding bleach to get between 15-20 (according to the SLAM targets with my CYA level) and brushing right away... and went to BJ's to get a few more cases of bleach just in case.
    When I came back, I changed out the filter, so this was change #3 - hard to believe how filthy it was when the water looks relatively clear!
    Couple of hours and filter changes later, the bleach was holding at 18ppm, so I threw in all the tools I've been using and now I'm just getting ready for my first OLCT - wish me luck!!
    I LOVE THIS SITE and how easy it's been making taking care of a pool!
    17' x 30' plaster pool, Intellipro Variable Speed pump, filter that's about to be replaced, 1 skimmer and 2 returns, and that's about all I know about this pool!
    4' ledge all the way around, deep "scoop" about 9' deep - NO DIVING!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Re: First ever battle with algae
    Good Luck Minxcal!
    I'm so glad you know what to do! This evenining I really don't feel like typing the process start to finish like a newbie would need!
    let us know how long it takes to clear it up!
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good job minx!
    Glad to hear the forum is helping you out. Looks like you have enough chlorine to get control of this, or at least the bulk of it. Curious where all the dirt comes from. Do you get run off from the surrounding surfaces into the pool?
    Essential Links:
    Mar 2015
    Scottsdale, AZ
    1
    Good job, minxcal! Looks like you have a nice handle on things.
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Thanks, all. Not done yet. Dropped 2ppm.
    Patrick_B - I think the dirt usually just comes through the screen. We're a block from the beach on a busy road and we've figured out through millions of noseeum bites that the cage is screened with regular screen.
    Looks a whole lot better, though!
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Quote Originally Posted by minxcal View Post
    Oops! Accidentally replied to my own post and can't seem to find how to delete it.
    Thank you all for the encouragement!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Piece of cake this one! Looking pretty good already, and it will be in top shape in no time. Good work.
    Essential Links:
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Once I get this cleaned up, I was thinking of adding borates, but going the easy route with something like ProTeam Supreme Plus. I had hives all day last time I used any MA. Thoughts?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, I don't believe the MA had anything to do with your Hives. You may be a good candidate for borates, and a lot of people like them. I don't think adding them to eliminate hives should be a motivation however. Your fill water TA and pH are the important considerations when considering borate addition to your pool.
    Essential Links:
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Oh, I didn't mean add them to avoid hives... I meant last time I used MA, I got hives. I've got super sensitive skin. I'd prefer to not have to use gallons of it to add Borax.
    Anyway, FC dropped 1 1/2ppm overnight last night. Day three about to commence!
    Casey's Avatar
    SW PA
    10,461
    I wouldn't check for an OCLT until you can see the screws on the main drain in deep end if you have one. Keep SLAM'ing, brushing n sweeping.
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Oh it's as clear as it's ever been. Just still losing chlorine at night
    Hard to get a good shot while it's still in the shade.
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Sun's over the pool now. Hard to believe I'm still SLAMming when the water looks so inviting! And I NEVER registered any CC. Goes to show!
    May 2014
    Clarksburg, WV
    331
    That is looking alot better. Great job.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Thanks so much! Passed the OCLT this morning. Time to give that pump a short break for the day and change the filter for good! Whew!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's great. It's so easy once you top the hill. Good job there!
    Essential Links:
    Casey's Avatar
    SW PA
    10,461
    It looks so much better!
