Results 1 to 7 of 7
Thread: Low Water Return from Filters to the Pool
    Mar 2015
    Dixon,CA
    3
    We have a 4 cartridge system - filters are newer and cleaned frequently. Values have been checked and are open, PSI is at 30 and still getting low water return to the pool. Thoughts??
    30,431
    Re: Low Water Return from Filters to the Pool
    Welcome to the forum.
    More often than not, your symptoms are perfectly normal.
    Your filter is doing what it should be doing.....filtering and catching debris from your pool water. This extra debris causes your psi to go up (30 is w-a-a-ay too high) and restricts the flow into the pool.
    My guess is you are not keeping enough chlorine in your water to prevent algae growth so, even though your water may look clear, you are filtering algae which will constantly and forever clog your filter until you get rid of it.
    1. Can you post a full set of test results....
    FC
    CC
    pH
    CH
    CYA
    2. What does your water look like?
    3. What is your normal psi when the filters have just been cleaned?
    Mar 2015
    Dixon,CA
    3
    Thanks for the warm welcome - good friend recommended this site
    Yes, we have been battling algae and major debris - high wind lots of leaves...
    Our test kit only shows FC / pH - we normally have results done at local hardware store ... more to come on that..
    Currently water looks cloudy and still have algae on the bottom
    Normal PSI around 20 - before fall / winter..
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    To get rid of the algae bloom you need to follow the SLAM Process
    To be able to SLAM the pool your going to need an accurate way to test your water chemistry. These are the Test Kitswe recommend for accurate water testing. The TF100 is the best value. Order it with the XL option. That will give you the extra reagents for the SLAM process.
    Next I suggest you do some reading in Pool School to get up to speed on your water chemistry. Here are a few good articles to start with.
    ABC'S Of Pool Water Chemistry
    How To Chlorinate Your Pool
    When you have questions as I'm sure you will don't hesitate to ask ! Keep all your questions in this thread as it makes it easier for everybody to see your history.
    If you could add all your pool and equipment info to your sig that will help us better help you.
    Thanks Jeff
    Jeff
    Mar 2015
    Dixon,CA
    3
    Thanks Jeff - We will get right on it and report back to this thread!!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sounds good ! We'll wait for ya to report back.
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    +1 on everything pwrstrk says.
    Divin Dave,
