Can rust cause PH levels to fall? I had a few patches I repaired in my faux waterfall feature, areas of which extend below the water line, and wonder if some of the shavings got into the water.
Get the FC up
I would assume the CYA is up around 80ppm and use that for the FC target for now ... err on the high side to be safe.
It is normal to lose 2-3ppm of FC every day. That is about 1/2-3/4 of a gallon of 10% every day.
Lowering the CYA would actually increase the daily losses due to less protection from the sun.
The higher you raise the FC, the more ppm you will lose in a day.
With a CYA of 80ppm, you need to stay above 6ppm at all times. So everyday you should be raising the FC up to about 9ppm so it never drops below 6ppm by the next day when you add more.
With a CYA that high and the cooler water temps and less intense sun, I would think you should be losing closer to 2ppm a day at normal FC levels.
When I say lowering I mean replacing water in your pool to get a lower ppm.
There is no ideal CYA level and it has nothing to do with your pool size.
For a non-SWG pool we say 30-50ppm. For a SWG pool we say 70-80ppm.
It really depends on the amount and intensity of the sun. Here is AZ, with a non-SWG pool, someone may want to raise the CYA to be in the 50-60ppm range, but there is really nothing wrong with being higher yet. The higher CYA only becomes a bit of an issue when you have to SLAM the pool and FC levels get to be very high.
I suggested before to lower your CYA level to 60. You won't have to drain half of your water to get it from 80 to 60. Pool Math will tell you how much water needs to be replaced to get from 80 to 60.
Now if you choose to leave it at 80 you just have to monitor your FC levels so you don't fall below your min FC level. You don't want to fight an algae outbreak at a CYA level of 80. You want to target your FC at 11 and never below 6 for a CYA level of 80.
Another reason for lowering your CYA is your PH test reads a false high with FC levels of 10 or higher. If you leave your CYA at 80 just make sure you test your PH level when the FC level is below 10.
I checked for you. To lower your CYA to 60 you would need to replace 25% of your water.
