Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Fiber Clear and Sta-Rite PLD50
    Sep 2014
    Harvard, MA
    28
    I have recently started using Fiber Clear instead of DE in my filter and I am very pleased with the improved clarity of the water. However, we have an ongoing iron problem and have used metal Sequestrants to keep it somewhat under control. I notice on the Fiber Clear package that it warns against using Sequestrants. I am wondering if this would apply to metal Sequestrants as well as to coagulant style clarifying Sequestrants? I have tried to contact Fiber Clear with this question, but they are not getting back to me.
    New 4,500 gallon vinyl Endless Pool, Sta-rite PLD50 DE filter, indoor, heated. Well water with iron and copper.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Fiber Clear
    Well, I just don't know, but I'll be interested in the answer. I'm curious, is this caution because it fouls the media so quickly that it makes it cost prohibitive to recharge it so often?
    Essential Links:
    Re: Fiber Clear
    That is curious. Many sequestrants specifically recommend using fiber products as a filter aid when using sequestrant.
    Is it possible that you are mixing up sequenstrants with clarifiers? I can at least imagine not recommending clarifiers with fiber, even though there isn't normally such a restriction.
    Sep 2014
    Harvard, MA
    28
    Re: Fiber Clear
    Their website says that Sequestrants and clarifiers will make the pressure rise and turn the Fiber Clear into a gelatanous substance that will be hard to clean off the filter. The bag says that metals "removers" can be used, but not if clarifiers or polymers are added to them. I thought most of the "removers" were Sequestrants. As frequently pointed out in this forum, there really isn't a product on the market that actually removes metals. Not that I've found anyway, and I've tried them all. Does anyone know of a metals product that does not have clarifiers or polymers in it?
    Re: Fiber Clear
    So they are worried about clarifiers, and are simply assuming that sequestrant contains clarifier (which it usually does not, but occasionally does). I can understand that.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Fiber Clear
    I don't specifically know, but your question on that will be answered. As Jason said, most of them don't have them. "Flocs" and "Clarifiers"/Coagulants look to be the concern. Any reason you don't use regular Pool Filter DE? DE gets a pool about as clear as it can be done. I'm not criticizing you for using it, just curious why DE isn't to your satisfaction.
    Essential Links:
    Sep 2014
    Harvard, MA
    28
    Re: Fiber Clear
    I don't like the DE because of the breathing and environmental issues, so I thought I would give Fiber Clear a try and it actually made the pool clearer. It's a lot easier to backwash, too. And it weighs a fraction of what DE weighs, which is a plus for this 67 yr old grandma. I like everything about it, if I can just figure out this metals issue.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Fiber Clear
    OK, I understand. Well, metals are tough, and the only options you have really are a new cleaner water source, or constant addition of sequestrants. Unfortunately, there just aren't many options when it comes to metals.
    Essential Links:
    Sep 2014
    Harvard, MA
    28
    Re: Fiber Clear
    So my question remains, can anyone recommend metals products that do NOT contain coagulants or polymers?
    Thanks
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Fiber Clear
    Hi,
    I sent a request to Customer Support at Fiber Clear about using Jacks Magic metal sequestrant. Hopefully they will reply back.
    If and when they do, I will let you know what they said.
    I also sent email to Jacks Magic. Jacks Magic also sells cellulose alternative to DE as well as sequestrants.
    I will let you know if I hear back from them.
    Divin Dave,
    30,414
    Re: Fiber Clear
    1. How many ppm of iron do you have? Is it in your fill water?
    2. It seems fiber clear is the real stumbling block. Any thoughts on going to DE and taking fiber clear out of the equation?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Fiber Clear
    She doesn't like the DE for health and handling reasons. Perhaps chemgeek can give her some more tips on chemicals she wants.
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Fiber Clear
    She hasn't said what brand of sequestrant's she's using. Jack's sells fiber alternative themselves. Now if they recommend using both at that same time is another question.
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Fiber Clear
    Ive no doubt that's exactly what Jack Magic will say.
    Looking at the MSDS, both fiber clear and Jacks magic fiber is made of cellulose, (they all are as far as I can tell). the main difference that I can find is mostly just the fiber sizes. If so, then I think it would be reasonable to think they would react the same... but Im not 100% sure. Hopefully, they will send a reply back to me. Will be interesting to see what each of them say.
    Quote Originally Posted by pwrstrk View Post
    Divin Dave,
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Fiber Clear
    Looking forward to their replies as that will be some good info for my back pocket !!
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Fiber Clear
    Yup. Sure will.
    Divin Dave,
    Jan 2013
    Long Island, NY
    184
    Re: Fiber Clear
    What about AquaPerl. It's perlite, a substitute for DE and celluose. http://www.intheswim.com/p/aqua-perl
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Sep 2014
    Harvard, MA
    28
    Re: Fiber Clear
    Thank you, Dave. I really appreciate your help. My iron is 2ppm, and by the way, if you are still looking for feedback on CuLator. It did not work at all for me. I used it for three consecutive months and it did not affect the iron count at all.
    The sequestrant I have on hand right now is Metal Magic, but Pool Magnet is the one I have found most effective.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Fiber Clear
    Both ProTeamŽ Metal Magic and BioGuardŽ Pool Magnet Plus have HEDP as the metal sequestrant. Since this is not a polymer, there should be no problem using them with Fiber Clear.
  20. Back To Top    #20
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Fiber Clear
    Thank you chem geek.
    JackieK,
    If chem geek says it's so, believe it. He is the TFP residential chemical genius!
    When it comes to chemistry, he rocks.
    Divin Dave,
